I2C Expansion Board
(07-21-2016, 12:59 PM)Artyom Wrote:
(07-21-2016, 11:15 AM)DonFL Wrote: Hoping to get some insight from anyone who is successfully using the I2C expansion board.
I'm using the Pine temp/humidity sensor...tested with some python code (grabbed from the web and modified) and the sensor works great when using the Pi Bus I2C pins. It also works with the I2C expansion board plugged in and connected to the expansion board pins.
When I plug into one (any) of the I2C expansion board ports, nada...I get an I/O error. After some quick troubleshooting, I see that the device is no longer seen on the I2C bus when i do an i2cdetect command. The fact that the bus pins are confirmed functional, and its specifically with the board ports, it suggests to me there is something more needed that I'm missing.
I have a second I2C expansion board, same issue, so would not appear the board is defective.
Jumpers are on the 3.3v pins as I've confirmed they should be.
I'm running debian-mate, and since I2C works from the bus pins, I don't see it as an OS issue. KH Goh mentioned checking bus speed and confirming its at 10 khz, but would think bus speed would not be a factor as far as being able to see the device on the bus. That said, if anyone can tell me where within the OS configs I can check I2C bus speed, I'd love to eliminate that possibility and also know where it is for future reference.
There is not a lot of detail on the wiki page regarding the expansion board, but I interpret what is there to suggest that I should be able treat the expansion ports just like I would a connection direct to the bus pins.
Thoughts?
Try to send those info to TL Lim. I have 1 I2C POT Board. And I have this problem too. Without Board all sensors detect and work. With board sensors doesn't work. It is because port on board connected to the I2c port witch linux don't see... As I undestand correctly...
 KH Goh, who is part of the Pine team, is who I've been in contact with. I'll forward to TL also.
I2C_0 is the pi bus port, you're thinking the expander uses I2c_1? Not seeing where that port is exposed on any of the headers..??
I did actually change the port in my code last night as part of my testing/troubleshooting, and saw no difference. I also don't see the device when doing an i2cdetect command on either port.
I2C Expansion Board - by DonFL - 07-21-2016, 11:15 AM
RE: I2C Expansion Board - by Artyom - 07-21-2016, 12:59 PM
RE: I2C Expansion Board - by DonFL - 07-21-2016, 01:17 PM
RE: I2C Expansion Board - by khgoh - 07-21-2016, 07:16 PM
RE: I2C Expansion Board - by MarkHaysHarris777 - 07-21-2016, 10:34 PM
RE: I2C Expansion Board - by DonFL - 07-22-2016, 12:28 AM
RE: I2C Expansion Board - by khgoh - 07-26-2016, 02:59 AM
RE: I2C Expansion Board - by MarkHaysHarris777 - 07-26-2016, 07:09 AM
RE: I2C Expansion Board - by DonFL - 07-26-2016, 05:19 AM
RE: I2C Expansion Board - by Artyom - 07-26-2016, 08:51 AM
RE: I2C Expansion Board - by MarkHaysHarris777 - 07-26-2016, 10:52 AM
RE: I2C Expansion Board - by DonFL - 07-26-2016, 09:03 AM
RE: I2C Expansion Board - by Artyom - 07-26-2016, 11:31 AM
RE: I2C Expansion Board - by khgoh - 07-26-2016, 09:17 PM
RE: I2C Expansion Board - by dkryder - 07-27-2016, 12:51 AM
RE: I2C Expansion Board - by pineadmin - 07-27-2016, 01:30 AM
RE: I2C Expansion Board - by Artyom - 07-27-2016, 12:07 AM
I2C Expansion Board - by Artyom - 07-27-2016, 08:16 AM
RE: I2C Expansion Board - by DonFL - 07-27-2016, 09:06 AM
RE: I2C Expansion Board - by xalius - 07-27-2016, 11:06 AM
RE: I2C Expansion Board - by Artyom - 07-27-2016, 11:17 AM
RE: I2C Expansion Board - by dkryder - 07-27-2016, 12:10 PM
RE: I2C Expansion Board - by Artyom - 07-27-2016, 12:20 PM
RE: I2C Expansion Board - by dkryder - 07-27-2016, 05:58 PM
RE: I2C Expansion Board - by martinayotte - 07-27-2016, 12:41 PM
RE: I2C Expansion Board - by xalius - 07-27-2016, 12:49 PM
RE: I2C Expansion Board - by martinayotte - 07-27-2016, 04:54 PM
RE: I2C Expansion Board - by martinayotte - 07-28-2016, 03:44 PM
RE: I2C Expansion Board - by martinayotte - 07-27-2016, 07:19 PM
RE: I2C Expansion Board - by khgoh - 07-27-2016, 09:33 PM
RE: I2C Expansion Board - by martinayotte - 07-28-2016, 09:14 AM
RE: I2C Expansion Board - by DonFL - 07-28-2016, 06:21 AM
RE: I2C Expansion Board - by khgoh - 07-28-2016, 04:28 PM
RE: I2C Expansion Board - by xalius - 07-28-2016, 03:58 PM
RE: I2C Expansion Board - by martinayotte - 07-28-2016, 05:46 PM
RE: I2C Expansion Board - by xalius - 07-28-2016, 06:28 PM
RE: I2C Expansion Board - by martinayotte - 07-28-2016, 07:19 PM
RE: I2C Expansion Board - by Artyom - 07-30-2016, 06:31 AM
RE: I2C Expansion Board - by tllim - 07-30-2016, 06:07 PM
RE: I2C Expansion Board - by AndrewC78 - 08-16-2022, 10:29 AM
  Poll: interest for SPDIF-only POT board? amp 0 3,746 05-01-2019, 11:17 PM
Last Post: amp
  Audio DAC pot board nejec 2 8,625 12-09-2017, 01:43 PM
Last Post: nejec
  Zwave Board: 300, 400 or 500? Lugor 4 11,541 01-10-2017, 08:55 PM
Last Post: Lugor
  Questions. board serial.? bongky youn 8 14,881 09-12-2016, 09:24 AM
Last Post: bongky youn
  My Board Layout Diagram UnixOutlaw 8 17,347 09-09-2016, 02:41 AM
Last Post: pfeerick
  New module: POT board Crispin 25 53,995 07-12-2016, 08:47 PM
Last Post: khgoh
  GPS expansion board stephen fleming 3 7,857 07-06-2016, 11:20 AM
Last Post: xalius
