changing from bullseye to bookworm to install mmsd-tng
(04-06-2023, 02:04 PM)zetabeta Wrote:
(04-05-2023, 10:26 PM)jyoung Wrote:
(04-02-2023, 05:33 PM)Kevin Kofler Wrote: See: https://blog.mobian-project.org/posts/20...-firmware/
Interesting... I added "non-free-firmway" to  /etc/apt/sources.list and  /etc/apt/sources.list.d/mobian.list, but "apt update" still fails with the same error. Zebulon Walton, the thread you linked had a lot of ideas, but they eventually converged on running " apt-get dist-upgrade" first. I did that, and it succeeded, however, running apt upgrade afteward still failed. That seems really strange to me, that the more rigorous update would succeed whereas the lighter one failed.
if you get same error, then probably keys are still missing.
curl -s https://repo.mobian.org/mobian.gpg | sudo tee /etc/apt/trusted.gpg.d/mobian.gpg
# or
wget -O - https://repo.mobian.org/mobian.gpg |  sudo tee /etc/apt/trusted.gpg.d/mobian.gpg
other hand, you could manually download https://repo.mobian.org/mobian.gpg file and copy it to /etc/apt/trusted.gpg.d/mobian.gpg . root or sudo is required.
i have a bad feeling that updating packages afterwards may be complicated, so i suggest aptitude.
That works, the update went through, without any complaints! I am having some weird problems now, though. My audio book player (cozy) won't play through the headphones. I'm guessing this is probably not related to the earlier issue, but any ides there?
RE: changing from bullseye to bookworm to install mmsd-tng - by jyoung - 04-09-2023, 08:06 AM
  Struggle to install LibreOffice on the PinePhone Peter Gamma 50 58,537 07-26-2024, 10:35 PM
Last Post: Peter Gamma
  Install OS Permanently ismkdc 1 2,623 03-20-2023, 01:13 PM
Last Post: fxc
  install packages pamac anbox neithan76 0 1,461 07-18-2022, 07:13 AM
Last Post: neithan76
  Beta support: MMS on chatty/mmsd on Modem Manager - help/testing wanted! kop316 201 277,389 03-24-2022, 03:16 AM
Last Post: as365n4
  Streamlined jmms install amindfv 1 2,792 10-29-2021, 07:04 AM
Last Post: TRS-80
  Python3 Bridge SMS/MMS to Matrix using Modem Manager and MMSD FutureBucket 3 5,871 02-10-2021, 08:09 PM
Last Post: kop316
  Anbox: install Google Services sonic 0 2,686 02-07-2021, 04:45 AM
Last Post: sonic
  Install OS directly to eMMC? tahayassen 11 21,216 10-10-2020, 03:56 PM
Last Post: electricprism
  Changing the boot loader Boern 1 4,304 04-12-2020, 11:22 AM
Last Post: wibble
