Modem gets disabled on every suspend
(03-16-2023, 04:01 AM)jojuma Wrote:
Quote:If it says "disabled", try "sudo nmcli radio wwan on".
This is supposed to start it, but only once, right? That's what I had before...
Well, no, NetworkManager should remember it. What you had before was enabling ModemManager directly through mmcli, bypassing NetworkManager. So NetworkManager still thinks it should be disabled and disables it on startup or resume.
My guess is that you had disabled mobile data with a Plasma Mobile from between December 2021 and March 2022 (keep in mind that preinstalled images on newly shipped phones can be several months out of date), where the mobile data toggle would set the wwan flag in NetworkManager to disabled, disabling the entire modem. Then upgrading to a fixed Plasma Mobile left you with the flag still set incorrectly in NetworkManager, without a UI toggle to fix it. So try my nmcli command.
There may be other ways to end up in this state though. What matters is how to get out of it.
Modem gets disabled on every suspend - by jojuma - 03-12-2023, 12:57 PM
RE: Modem gets disabled on every suspend - by Kevin Kofler - 03-17-2023, 06:52 AM
  Modem white list aular 7 830 02-13-2024, 04:35 PM
Last Post: aular
  qcell modem id aular 6 810 01-15-2024, 10:05 PM
Last Post: aular
  Temporary fix for Modem Not Coming Back on in SXMO Postmarketos Pinephone kebab 2 2,067 07-16-2023, 11:14 AM
Last Post: kebab
  Modem audio settings jack1 2 1,292 02-04-2023, 04:01 PM
Last Post: jack1
  Phone won't suspend, battery drains quickly nelstomlinson 12 7,187 04-05-2022, 06:11 AM
Last Post: Anna
  The modem switch affects the connection to battery? JohnDoe 2 2,013 03-30-2022, 12:02 AM
Last Post: JohnDoe
  Modem disabled, can't enable: Invalid transition pac 4 3,505 03-23-2022, 01:08 PM
Last Post: Firewave
Question Modem problems with the distros I tried UltraBlack_ 9 5,247 02-21-2022, 01:57 PM
Last Post: KNERD
Big Grin troubleshooting Chatty / modem? no SMS outbound vap0rtranz 5 3,626 02-14-2022, 12:15 PM
Last Post: vap0rtranz
  PinePhone Beta 3GB modem not working hannescam 15 9,040 01-19-2022, 02:08 AM
Last Post: bcnaz
