Remove Grayed-Out Alarm Icon from Panel?
(03-02-2023, 09:32 AM)alaraajavamma Wrote:
(03-02-2023, 09:29 AM)jakfish Wrote: With PP Community/Physical kb/Manajro Phosh Beta 29, I have a grayed-out Alarm-or-Bell icon next to the battery icon. Is there any way to remove that? I don't use the PP for any alarms.
Thanks.
You have silent mode enabled. Turn your notification settings to On or vibration and the icon will disappaer (you will lose silent mode but it will disappaer Smile )
Very much appreciate your fast reply. Since you've posted, I've examined my Settings but cannot find "silent mode" or anything about vibrate. Could you tell me where to look, or is this a terminal command?
Again, thank you for posting.
Never mind: found it in Quick Settings. I must've ticked it by accident. Thanks again.
RE: Remove Grayed-Out Alarm Icon from Panel? - by jakfish - 03-02-2023, 09:49 AM
  Screen timeout makes alarm and timer unusable... Eugo 9 5,207 10-03-2022, 01:41 AM
Last Post: Eugo
  Danger icon on mobile network avodá 6 4,198 05-12-2022, 06:57 PM
Last Post: Chief
  How to remove Manjaro Phosh lock screen password? Avisando 4 4,510 10-28-2021, 04:20 AM
Last Post: Avisando
  How to find and remove junk files from failed updates? danimations 4 3,970 10-24-2021, 11:25 PM
Last Post: danimations
  How to remove weird desktop/homescreen icons? jojuma 2 2,494 10-11-2021, 01:36 PM
Last Post: jojuma
