Nheko - Missing GStreamer plugins videoconvert
(03-01-2023, 05:06 PM)anonymous Wrote: I wish you good luck, I failed to use Jitsi Meet for a similar purpose.
Try
sudo apt install gstreamer1.0-libcamera gstreamer1.0-plugins-bad
Thanks for your advice, be appear, a problem is again present with ov5640 camera.
[2023-03-03 21:21:04.609] [ui] [info] WebRTC: initialised GStreamer 1.22.0
[0:44:48.815765468] [4327]  WARN IPAManager ipa_manager.cpp:154 No IPA found in '/usr/lib/aarch64-linux-gnu/libcamera'
[0:44:48.816289511] [4327]  INFO Camera camera_manager.cpp:299 libcamera v0.0.4
[0:44:48.839455703] [4342]  WARN CameraSensor camera_sensor.cpp:245 'ov5640 3-004c': Recommended V4L2 control 0x009a0922 not supported
[0:44:48.839581620] [4342]  WARN CameraSensor camera_sensor.cpp:312 'ov5640 3-004c': The sensor kernel driver needs to be fixed
[0:44:48.839646787] [4342]  WARN CameraSensor camera_sensor.cpp:314 'ov5640 3-004c': See Documentation/sensor_driver_requirements.rst in the libcamera sources for more information
[0:44:48.839700120] [4342] ERROR CameraSensor camera_sensor.cpp:336 'ov5640 3-004c': Mandatory V4L2 control 0x009e0903 not available
[0:44:48.839744912] [4342] ERROR CameraSensor camera_sensor.cpp:344 'ov5640 3-004c': The sensor kernel driver needs to be fixed
[0:44:48.839788579] [4342] ERROR CameraSensor camera_sensor.cpp:346 'ov5640 3-004c': See Documentation/sensor_driver_requirements.rst in the libcamera sources for more information
[0:44:48.839917246] [4342] ERROR SimplePipeline simple.cpp:1433 No valid pipeline for sensor 'ov5640 3-004c', skipping
[0:44:48.840785332] [4342]  WARN CameraSensor camera_sensor.cpp:245 'gc2145 3-003c': Recommended V4L2 control 0x009a0922 not supported
[0:44:48.840991207] [4342] ERROR V4L2 v4l2_subdevice.cpp:400 'gc2145 3-003c': Unable to get rectangle 2 on pad 0: Ioctl() inapproprié pour un périphérique
[0:44:48.841105541] [4342]  WARN CameraSensor camera_sensor.cpp:287 'gc2145 3-003c': The PixelArraySize property has been defaulted to 1600x1200
[0:44:48.841162666] [4342] ERROR V4L2 v4l2_subdevice.cpp:400 'gc2145 3-003c': Unable to get rectangle 1 on pad 0: Ioctl() inapproprié pour un périphérique
[0:44:48.841222500] [4342]  WARN CameraSensor camera_sensor.cpp:298 'gc2145 3-003c': The PixelArrayActiveAreas property has been defaulted to (0, 0)/1600x1200
[0:44:48.841403959] [4342] ERROR V4L2 v4l2_subdevice.cpp:400 'gc2145 3-003c': Unable to get rectangle 0 on pad 0: Ioctl() inapproprié pour un périphérique
[0:44:48.841480500] [4342]  WARN CameraSensor camera_sensor.cpp:306 'gc2145 3-003c': Failed to retrieve the sensor crop rectangle
[0:44:48.841541584] [4342]  WARN CameraSensor camera_sensor.cpp:312 'gc2145 3-003c': The sensor kernel driver needs to be fixed
[0:44:48.841590251] [4342]  WARN CameraSensor camera_sensor.cpp:314 'gc2145 3-003c': See Documentation/sensor_driver_requirements.rst in the libcamera sources for more information
[0:44:48.843438673] [4342]  WARN CameraSensorProperties camera_sensor_properties.cpp:231 No static properties available for 'gc2145'
[0:44:48.843514715] [4342]  WARN CameraSensorProperties camera_sensor_properties.cpp:233 Please consider updating the camera sensor properties database
[0:44:48.843581840] [4342]  WARN CameraSensor camera_sensor.cpp:460 'gc2145 3-003c': Failed to retrieve the camera location
[0:44:48.843686840] [4342] ERROR V4L2 v4l2_device.cpp:352 'gc2145 3-003c': Unable to set controls: Permission non accordée
[0:44:48.843900716] [4342] ERROR SimplePipeline simple.cpp:1433 No valid pipeline for sensor 'gc2145 3-003c', skipping
RE: Nheko - Missing GStreamer plugins videoconvert - by freelectro - 03-03-2023, 02:24 PM
  GStreamer Camera Issue (Unsupported pixformat: 0x56595559 with mbus code: 0x3001) sog8b 1 2,573 07-17-2023, 01:49 AM
Last Post: junelung
  Magnetometer missing moxx 0 1,453 11-09-2022, 05:44 AM
Last Post: moxx
  Can't Get Nheko To Work [never mind, it's a bug] el.pollo.diablo 0 1,655 08-02-2022, 02:11 AM
Last Post: el.pollo.diablo
  LibreOffice Fix for tiny menu text and missing title bar grump_fiddle_reinstall 0 1,578 05-29-2022, 11:56 PM
  Self-compiled GTK4: artefacts and missing icons Zombie Feynman 4 5,533 02-06-2022, 05:42 AM
Last Post: Zombie Feynman
  Software update missing on desktop MikeMan 1 2,690 01-27-2022, 06:10 AM
Last Post: bcnaz
  Wi-Fi adapter suddenly gone missing Zebulon Walton 1 2,630 11-15-2021, 05:20 PM
  Getting Newer Version of Nheko publiclewdness 2 3,600 10-27-2021, 06:16 AM
Last Post: publiclewdness
  Is there an encryption package missing from mobian? rp3 0 2,499 01-27-2021, 05:16 AM
Last Post: rp3
