Bogus default gateway keeps appearing
Oops, didn't stop to think that was a MAC address. As you said, not a whole lot of damage there but I went ahead and edited out the details anyway.
I did not have any other network adapters or a VPN active, though OpenVPN is installed. This just started happening fairly recently so I was wondering if it had to do with a Mobian update.
Running ifconfig with WiFi, USB tethering, and OpenVPN active results in the following adapters listed by ifconfig:
wlan0                      #WiFi
usb0                        #USB tether
tun0                        #VPN
lo                            #Loopback
enxxxxxxxxxxxx     #???????
I have not had the dongle connected to this thing in a long time, probably close to a year, but will check its MAC address.
To make things even more confusing, rebooting the phone after installing updates resulted in the bogus default route not being added, and that adapter now only has an ipv6 address bound to it. (Prior to rebooting it had a 192.168.225.x address. Network-manager was included in the updates which may or may not have something to do with it.) Bizarre, will have to keep an eye on it.
RE: Bogus default gateway keeps appearing - by Zebulon Walton - 02-21-2023, 11:28 AM
  4G data on default startup / boot dcinoz 1 863 04-29-2023, 11:24 PM
Last Post: dcinoz
  Change default program for a file type 3x5co 1 1,785 09-01-2021, 05:26 PM
  Default SMS app send button off screen in vertical orientation motox6 0 1,260 05-22-2021, 02:55 PM
Last Post: motox6
  Desktop Entry icon not appearing: how to diagnose? Saliency 6 5,191 03-15-2021, 05:49 AM
Last Post: kqlnut
  Make 'terminal' on-screen keyboard the default 3x5co 0 1,841 12-27-2020, 05:11 PM
Last Post: 3x5co
  ssh not enabled, by default? RodMyers 6 6,042 10-02-2020, 07:35 AM
Last Post: LinAdmin2
  sudo / lock screen password keeps resetting to default ergo owl 6 6,965 09-04-2020, 06:07 AM
Last Post: ergo owl
  How to change the minimum password length when changing from default passwords arturo2bodegas 3 4,600 07-18-2020, 01:51 PM
Last Post: arturo2bodegas
  Default Theme wasgurd 4 6,079 06-26-2020, 06:28 PM
Last Post: wasgurd
