SIM Card Slot Terror
It's the sort of solder job a phone repair place should probably be able to do, so long as you can get the part. @tllim said a while back that they had obtained some spares which you might be able to get by filing a support ticket. It's also been suggested the LG G4 has a socket that's a close match, but I don't know if anyone has actually tried it as a replacement. It wouldn't hurt to ask how much it would cost for the soldering, then judge whether it's worth a try or better just to replace it.
SIM Card Slot Terror - by thismarty - 12-15-2022, 11:00 AM
RE: SIM Card Slot Terror - by traut - 12-15-2022, 01:12 PM
RE: SIM Card Slot Terror - by wibble - 12-16-2022, 12:57 PM
RE: SIM Card Slot Terror - by tllim - 12-19-2022, 08:14 PM
RE: SIM Card Slot Terror - by thismarty - 12-21-2022, 05:37 PM
  install iso from sd card to emmc aular 2 322 03-11-2024, 10:24 PM
  How To Access the Pine Phone Auxillary microSD Without Removing Card pinephoneuser22 2 940 01-09-2024, 07:02 PM
Last Post: britelite
  new pinephone regular model with nano-sim slot zetabeta 0 650 09-24-2023, 12:25 AM
Last Post: zetabeta
  SD Card has wrong capacity AndyM 11 2,363 06-11-2023, 12:30 AM
Last Post: AndyM
  Device Unable To Read MicroSD Card _radv_ 19 6,134 02-18-2023, 02:01 PM
Last Post: _radv_
  MicroSD Card Reuse _radv_ 5 2,017 12-12-2022, 12:26 PM
Last Post: chainingsolid
  Pine Phone Doesn't Recognize New MicroSD Card _radv_ 3 1,420 11-23-2022, 05:19 AM
Last Post: _radv_
  SIM Card Install pineme 4 5,128 06-10-2022, 03:15 AM
Last Post: rocket2nfinity
  SIM card slot not working dekrets 2 2,203 02-12-2022, 11:09 AM
Last Post: dekrets
  PinePhone SIM slot Niek 14 13,401 01-29-2022, 03:23 PM
Last Post: u20200719
