An early xmas present: 6.1 kernel
Actually having run 6.1 for a little while now I'm finding the phone has stability problems with it. I've had several spontaneous reboots which was never a problem with 5.15. (Thankfully the modem firmware wasn't corrupted.)
So for now I edited /boot/extlinux/extlinux.conf to make the older kernel the default. (I'm glad now I made the /boot partition larger so it can hold both kernels!) Will give 6.1 a try again in the future after it's updated.
An early xmas present: 6.1 kernel - by treebeard - 12-14-2022, 09:23 AM
RE: An early xmas present: 6.1 kernel - by wibble - 12-15-2022, 01:51 AM
RE: An early xmas present: 6.1 kernel - by Zebulon Walton - 12-21-2022, 11:04 AM
  how to disable ipv6 at kernel level with towboot? vusra 3 3,256 10-04-2024, 04:23 AM
Last Post: vusra
  Stability problems with 6.1 kernel Zebulon Walton 9 6,985 05-12-2023, 08:09 AM
Last Post: zetabeta
  Kernel 5.15 Zebulon Walton 10 11,120 11-27-2021, 01:10 PM
Last Post: LibrePhoneUser
  Mobian kernel upgrade user641 4 6,474 11-10-2021, 01:22 PM
Last Post: user641
  kernel upgrade user641 2 4,050 09-13-2021, 08:26 AM
Last Post: user641
  [Solved] How to get a kernel newer than 5.10 on Mobian ? gab 0 2,203 08-26-2021, 04:08 PM
Last Post: gab
  Kernel fault on adapter connect pinephone.damiano 0 1,831 08-15-2021, 04:25 AM
Last Post: pinephone.damiano
  Is the A64’s true hardware random generator activated in Mobian’s 5.10 kernel build? LibrePhoneUser 3 6,117 01-17-2021, 12:44 PM
  Phone doesn't boot after latest kernel update Boern 12 18,873 08-06-2020, 11:34 AM
Last Post: Boern
  How to compile the kernel? Boern 3 6,807 08-04-2020, 08:38 AM
Last Post: Boern
