An early xmas present: 6.1 kernel
when i read first time, i initially thought that 6.1 was built separately, and it was needed to install separately if used. however, it's available from mobian repositories. although, sunxi kernel does not have meta package which links the latest package.
so far 6.1 seems to work.
package names:
linux-image-6.1-sunxi64
linux-headers-6.1-sunxi64
An early xmas present: 6.1 kernel - by treebeard - 12-14-2022, 09:23 AM
RE: An early xmas present: 6.1 kernel - by wibble - 12-15-2022, 01:51 AM
RE: An early xmas present: 6.1 kernel - by zetabeta - 12-19-2022, 05:52 PM
  how to disable ipv6 at kernel level with towboot? vusra 3 3,256 10-04-2024, 04:23 AM
Last Post: vusra
  Stability problems with 6.1 kernel Zebulon Walton 9 6,985 05-12-2023, 08:09 AM
Last Post: zetabeta
  Kernel 5.15 Zebulon Walton 10 11,120 11-27-2021, 01:10 PM
Last Post: LibrePhoneUser
  Mobian kernel upgrade user641 4 6,474 11-10-2021, 01:22 PM
Last Post: user641
  kernel upgrade user641 2 4,050 09-13-2021, 08:26 AM
Last Post: user641
  [Solved] How to get a kernel newer than 5.10 on Mobian ? gab 0 2,203 08-26-2021, 04:08 PM
Last Post: gab
  Kernel fault on adapter connect pinephone.damiano 0 1,831 08-15-2021, 04:25 AM
Last Post: pinephone.damiano
  Is the A64’s true hardware random generator activated in Mobian’s 5.10 kernel build? LibrePhoneUser 3 6,117 01-17-2021, 12:44 PM
  Phone doesn't boot after latest kernel update Boern 12 18,873 08-06-2020, 11:34 AM
Last Post: Boern
  How to compile the kernel? Boern 3 6,807 08-04-2020, 08:38 AM
Last Post: Boern
