An early xmas present: 6.1 kernel
Well - it almost worked.
The first gotcha was that I created the new ext4 filesystem using the old UUID but did not do that for the LUKS encrypted partition. (With full disk encryption it's the UUID of the LUKS encrypted partition that is looked for at boot time.) Once that was fixed using cryptsetup the phone booted up and everything seemed to be there. The boot partition is now 512MB, which should be plenty.
BUT - now the phone "thinks" the battery is at 0% charge so the modem and wifi will not come online. The last kind of problem I expected. I have two batteries and that's the case with both. Also the phone does boot up and otherwise run on the battery.
Spot-checking applications they seem to launch OK, except megapixels which bombs out saying it "could not find a /dev/media* node matching sun6i-csi". Checking. there are no /dev/media* files at all. Maybe a similar problem for the battery (device node missing)? Additionally when using the volume control it says the output device is "dummy output". So it does look like there is a device node problem going on here. Not sure why this would be since /dev entries have been created dynamically at boot time on Linux systems for a long time now. Expected entries for the eMMC and many other devices are there.
I had copied the backed-up Mobian system to the new filesystem using "cp -a" (the archive flag) to copy everything from the root of the drive while preserving permissions, so there should not be anything missing. Everything was done from a desktop Linux system with the phone connected via USB to access the eMMC.
Not sure what's going on here. If I can't figure it out will have to restore my image backup. In the meantime it's back to my emergency SD card.
An early xmas present: 6.1 kernel - by treebeard - 12-14-2022, 09:23 AM
RE: An early xmas present: 6.1 kernel - by wibble - 12-15-2022, 01:51 AM
RE: An early xmas present: 6.1 kernel - by Zebulon Walton - 12-16-2022, 07:50 PM
  how to disable ipv6 at kernel level with towboot? vusra 3 3,256 10-04-2024, 04:23 AM
Last Post: vusra
  Stability problems with 6.1 kernel Zebulon Walton 9 6,985 05-12-2023, 08:09 AM
Last Post: zetabeta
  Kernel 5.15 Zebulon Walton 10 11,120 11-27-2021, 01:10 PM
Last Post: LibrePhoneUser
  Mobian kernel upgrade user641 4 6,474 11-10-2021, 01:22 PM
Last Post: user641
  kernel upgrade user641 2 4,050 09-13-2021, 08:26 AM
Last Post: user641
  [Solved] How to get a kernel newer than 5.10 on Mobian ? gab 0 2,203 08-26-2021, 04:08 PM
Last Post: gab
  Kernel fault on adapter connect pinephone.damiano 0 1,831 08-15-2021, 04:25 AM
Last Post: pinephone.damiano
  Is the A64’s true hardware random generator activated in Mobian’s 5.10 kernel build? LibrePhoneUser 3 6,117 01-17-2021, 12:44 PM
  Phone doesn't boot after latest kernel update Boern 12 18,873 08-06-2020, 11:34 AM
Last Post: Boern
  How to compile the kernel? Boern 3 6,807 08-04-2020, 08:38 AM
Last Post: Boern
