An early xmas present: 6.1 kernel
Turns out the small /boot partition is going to be a real problem. I figured since I had a current image backup and the new kernel, might as well run updates. One of the updates was for the 5.15 kernel, so initramfs bombed out creating the initrd.img files due to lack of space. Tried removing the 5.15 kernel but apt wanted to also uninstall the pinephone-support package, so I didn't do that.
So I removed the 6.1 kernel, ran dpkg-reconfigure for the 5.15 kernel to rebuild initrd.img, and all is OK for now running on 5.15.
Since I'm using full disk encryption I believe it would require deleting the current eMMC installation and installing everything from scratch to make /boot larger - a major pain in the rear.
An early xmas present: 6.1 kernel - by treebeard - 12-14-2022, 09:23 AM
RE: An early xmas present: 6.1 kernel - by Zebulon Walton - 12-14-2022, 04:33 PM
RE: An early xmas present: 6.1 kernel - by wibble - 12-15-2022, 01:51 AM
  how to disable ipv6 at kernel level with towboot? vusra 3 3,256 10-04-2024, 04:23 AM
Last Post: vusra
  Stability problems with 6.1 kernel Zebulon Walton 9 6,985 05-12-2023, 08:09 AM
Last Post: zetabeta
  Kernel 5.15 Zebulon Walton 10 11,120 11-27-2021, 01:10 PM
Last Post: LibrePhoneUser
  Mobian kernel upgrade user641 4 6,474 11-10-2021, 01:22 PM
Last Post: user641
  kernel upgrade user641 2 4,050 09-13-2021, 08:26 AM
Last Post: user641
  [Solved] How to get a kernel newer than 5.10 on Mobian ? gab 0 2,203 08-26-2021, 04:08 PM
Last Post: gab
  Kernel fault on adapter connect pinephone.damiano 0 1,831 08-15-2021, 04:25 AM
Last Post: pinephone.damiano
  Is the A64’s true hardware random generator activated in Mobian’s 5.10 kernel build? LibrePhoneUser 3 6,117 01-17-2021, 12:44 PM
  Phone doesn't boot after latest kernel update Boern 12 18,873 08-06-2020, 11:34 AM
Last Post: Boern
  How to compile the kernel? Boern 3 6,807 08-04-2020, 08:38 AM
Last Post: Boern
