An early xmas present: 6.1 kernel
Big Grin
If you care for a stroll on the bleeding edge, A 6.1 kernel for the Pinephone has landed.
Download the deb, do a "sudo dpkg -i linux-image-6.1-sunxi64_6.1+sunxi64-1_arm64.deb", then reboot and you should be good. Do "uname -a" to check. The install doesn't overwrite anything related to the 5.15 kernel but will add a stanza to /boot/extlinux/extlinux.conf for the 6.1 kernel as the default entry. If you want/need to switch back to 5.15, changing the default selection should do it.
I'm hoping this might fix, or at least reduce, the "fail to wake" problems and perhaps take care of the spontaneous reboots as well. In any case, it sounds like 6.1 will be the kernel released in bookworm.
I've only been running it a couple hours but have gone through my usual post-upgrade checklist with no new issues. I haven't tested any bluetooth stuff.
An early xmas present: 6.1 kernel - by treebeard - 12-14-2022, 09:23 AM
RE: An early xmas present: 6.1 kernel - by wibble - 12-15-2022, 01:51 AM
  how to disable ipv6 at kernel level with towboot? vusra 3 3,880 10-04-2024, 04:23 AM
Last Post: vusra
  Stability problems with 6.1 kernel Zebulon Walton 9 8,315 05-12-2023, 08:09 AM
Last Post: zetabeta
  Kernel 5.15 Zebulon Walton 10 12,272 11-27-2021, 01:10 PM
Last Post: LibrePhoneUser
  Mobian kernel upgrade user641 4 7,311 11-10-2021, 01:22 PM
Last Post: user641
  kernel upgrade user641 2 4,428 09-13-2021, 08:26 AM
Last Post: user641
  [Solved] How to get a kernel newer than 5.10 on Mobian ? gab 0 2,437 08-26-2021, 04:08 PM
Last Post: gab
  Kernel fault on adapter connect pinephone.damiano 0 2,101 08-15-2021, 04:25 AM
Last Post: pinephone.damiano
  Is the A64’s true hardware random generator activated in Mobian’s 5.10 kernel build? LibrePhoneUser 3 6,734 01-17-2021, 12:44 PM
  Phone doesn't boot after latest kernel update Boern 12 20,618 08-06-2020, 11:34 AM
Last Post: Boern
  How to compile the kernel? Boern 3 7,448 08-04-2020, 08:38 AM
Last Post: Boern
