Pine Phone Pro audio on phone calls: discussion, support and tips
#51
I had similar issues and was looking for something that could handle calls reliably on my setup. Ended up using Active Calls call center software, and it worked better than I expected. It picked up SIP settings fast, and audio quality was solid without tweaking too many things. If the default apps are giving you trouble, it might be worth a try just to see if it gets things running smoother.
RE: Pine Phone Pro audio on phone calls: discussion, support and tips - by Habbytm - 10-13-2025, 07:46 AM
  bookworm vs trixie discussion for mobian in pinephone pro. zetabeta 21 12,796 10-20-2025, 07:01 AM
  Calls on ppp chbwzxgk 6 2,522 05-14-2025, 06:41 PM
Last Post: chbwzxgk
  Battery life thread: discussion, support and tips apink 12 9,630 03-01-2025, 10:39 AM
Last Post: d50zesl0g@mozmail.com
Question Calls: ALSA UCM config not making a difference with volume lightwo 6 4,364 05-17-2024, 04:23 AM
Last Post: lightwo
  Guide to Suitable Phone State Borealid 19 20,537 09-18-2023, 07:00 AM
Last Post: robocone
  Phone Attitude(Device orientation) lurkadillian 2 2,619 06-22-2023, 08:12 PM
Last Post: lurkadillian
  Any tips to improve the audio quality of calls on the PinePhone Pro? tux_life 2 3,371 05-12-2023, 12:58 PM
Last Post: alaraajavamma
  Mobian has new separate packages to support the PinePhone Pro mburns 22 17,413 04-10-2023, 12:02 PM
Last Post: mburns
  Pine Phone won't boot into recovery mode ninjapig26@gmail.com 3 4,362 02-18-2023, 06:14 PM
Last Post: fxc
  [Mobian] No return from locked phone arno_nuehm 1 2,201 02-06-2023, 07:57 AM
Last Post: arno_nuehm
