certain apps freeze
(11-21-2022, 01:17 PM)fxc Wrote:
(11-19-2022, 09:02 PM)shiny.tent Wrote:
(11-17-2022, 11:34 AM)fxc Wrote:
(11-17-2022, 09:20 AM)shiny.tent Wrote: Hi,
When i unboxed the phone, tried to update, nothing.  Followed these instructions (https://forum.pine64.org/showthread.php?tid=12459) got it working and updated via terminal.
Upon rebooting, everything working except settings app, terminal and a few other programs i don't use.
Any advice?
Best if you reflash a newer image, either by the USB Mass Storage or by microSD card. The instructions can be found here: https://wiki.pine64.org/wiki/PinePhone_Pro#Software
I installed manjaro phosh and started updates.  rebooted and this is what I was greeted with...  any ideas..
[Image: preview]
You might want to try distributions which are more stable, such as Mobian. Make sure you flash images to the whole disk and not to partition 1.
Got it fix, deleted the partition and installed magari phosh.  Thank you!
certain apps freeze - by shiny.tent - 11-17-2022, 09:20 AM
RE: certain apps freeze - by fxc - 11-17-2022, 11:34 AM
RE: certain apps freeze - by shiny.tent - 11-19-2022, 09:02 PM
RE: certain apps freeze - by fxc - 11-21-2022, 01:17 PM
RE: certain apps freeze - by shiny.tent - 11-21-2022, 01:20 PM
RE: certain apps freeze - by apink - 11-20-2022, 11:11 AM
  Not able to leave or switch apps bobjrsenior 7 4,324 03-11-2022, 02:44 AM
Last Post: magdesign
  Dev Addition - Manjaro/Phosh - Apps not activating iwm 5 3,809 02-08-2022, 01:11 PM
Last Post: iwm
