DietPi OS for Quartz64
#26
(11-17-2023, 09:38 AM)MichaIng Wrote: I am a bit lazy currently to move around and attach an actual HDMI monitor. Let me know whether you see this device as well and whether the auto-conversion plugin helps, and in case if the "speaker-test" command produces output. If not, I'll have a closer look. Not sure if some kernel build flag is needed for additional HDMI PCM controls in alsamixer.
I tried to set this up and it seems to have worked! Setting HDMI output to the "hw:0,0  : HDMI fe400000.i2s-i2s-hifi i2s-hifi-0" device which is also present on my machine seems to have done the trick. YouTube videos play sound, and mplayer/mpg123 suffice to play most music and videos. I think this should be set default for the SOQuartz builds for the Model A baseboard.
Thank you so much for all your help, and your efforts in maintaining this distro!
DietPi OS for Quartz64 - by MichaIng - 11-13-2022, 05:06 AM
RE: DietPi OS for Quartz64 - by mig - 03-06-2023, 10:54 AM
RE: DietPi OS for Quartz64 - by fxc - 03-06-2023, 04:11 PM
RE: DietPi OS for Quartz64 - by mig - 03-08-2023, 04:52 AM
RE: DietPi OS for Quartz64 - by balbes150 - 03-09-2023, 12:42 AM
RE: DietPi OS for Quartz64 - by MichaIng - 03-15-2023, 07:48 AM
RE: DietPi OS for Quartz64 - by hughsheehy - 03-26-2023, 03:29 AM
RE: DietPi OS for Quartz64 - by hughsheehy - 03-26-2023, 09:48 AM
RE: DietPi OS for Quartz64 - by hughsheehy - 04-05-2023, 07:01 AM
RE: DietPi OS for Quartz64 - by CounterPillow - 04-08-2023, 09:15 AM
RE: DietPi OS for Quartz64 - by balbes150 - 04-09-2023, 04:41 AM
RE: DietPi OS for Quartz64 - by CounterPillow - 04-09-2023, 07:59 AM
RE: DietPi OS for Quartz64 - by balbes150 - 04-10-2023, 01:24 AM
RE: DietPi OS for Quartz64 - by CounterPillow - 04-10-2023, 04:13 AM
RE: DietPi OS for Quartz64 - by hughsheehy - 04-10-2023, 02:45 PM
RE: DietPi OS for Quartz64 - by balbes150 - 04-11-2023, 01:01 AM
RE: DietPi OS for Quartz64 - by MichaIng - 09-26-2023, 09:21 AM
RE: DietPi OS for Quartz64 - by balbes150 - 09-27-2023, 02:14 AM
RE: DietPi OS for Quartz64 - by MichaIng - 09-29-2023, 09:37 AM
RE: DietPi OS for Quartz64 - by balbes150 - 09-29-2023, 02:02 PM
RE: DietPi OS for Quartz64 - by MichaIng - 09-29-2023, 02:17 PM
RE: DietPi OS for Quartz64 - by balbes150 - 09-30-2023, 04:44 AM
RE: DietPi OS for Quartz64 - by MichaIng - 09-30-2023, 06:27 AM
RE: DietPi OS for Quartz64 - by stormwyrm - 11-17-2023, 12:02 AM
RE: DietPi OS for Quartz64 - by MichaIng - 11-17-2023, 09:38 AM
RE: DietPi OS for Quartz64 - by stormwyrm - 11-17-2023, 10:22 AM
RE: DietPi OS for Quartz64 - by MichaIng - 11-17-2023, 10:45 AM
RE: DietPi OS for Quartz64 - by stormwyrm - 11-17-2023, 11:01 AM
RE: DietPi OS for Quartz64 - by MichaIng - 11-17-2023, 11:56 AM
RE: DietPi OS for Quartz64 - by stormwyrm - 11-17-2023, 12:18 PM
RE: DietPi OS for Quartz64 - by MichaIng - 11-17-2023, 12:52 PM
RE: DietPi OS for Quartz64 - by stormwyrm - 11-17-2023, 02:00 PM
RE: DietPi OS for Quartz64 - by MichaIng - 11-17-2023, 02:03 PM
RE: DietPi OS for Quartz64 - by stormwyrm - 11-17-2023, 02:23 PM
RE: DietPi OS for Quartz64 - by MichaIng - 11-17-2023, 02:26 PM
RE: DietPi OS for Quartz64 - by stormwyrm - 11-26-2023, 09:47 PM
RE: DietPi OS for Quartz64 - by MichaIng - 11-27-2023, 08:41 AM
RE: DietPi OS for Quartz64 - by stormwyrm - 11-29-2023, 02:47 AM
RE: DietPi OS for Quartz64 - by MichaIng - 11-29-2023, 10:41 AM
RE: DietPi OS for Quartz64 - by diederik - 11-29-2023, 07:34 PM
RE: DietPi OS for Quartz64 - by stormwyrm - 11-30-2023, 12:57 AM
RE: DietPi OS for Quartz64 - by MichaIng - 11-30-2023, 07:07 AM
RE: DietPi OS for Quartz64 - by diederik - 11-30-2023, 09:25 AM
RE: DietPi OS for Quartz64 - by MichaIng - 11-30-2023, 09:44 AM
RE: DietPi OS for Quartz64 - by diederik - 11-30-2023, 04:02 AM
RE: DietPi OS for Quartz64 - by sickos - 12-12-2023, 02:26 AM
RE: DietPi OS for Quartz64 - by kup4ooo - 07-16-2024, 12:18 AM
RE: DietPi OS for Quartz64 - by ifreislich - 08-08-2024, 07:42 AM
  irradium (based on crux linux) Quartz64 riscv64, aarch64 mara 6 14,182 09-01-2025, 10:26 AM
  How does CPU frequency scaling work on the Quartz64 pugzarecute 0 1,510 07-30-2025, 07:19 AM
Last Post: pugzarecute
  Armbian and LibreELEC and AltLinux for Quartz64 balbes150 152 142,030 03-23-2025, 01:10 AM
Last Post: balbes150
  USB on Quartz64 Zero litbulb 0 1,086 11-13-2024, 08:16 AM
Last Post: litbulb
  slarm64 (unofficial slackware) Quartz64 RK3566 (aarch64) mara 56 69,866 10-17-2023, 10:55 AM
  quartz64-a - on-board SATA port problems manning 2 3,656 09-14-2023, 04:22 PM
Last Post: manning
  How the reset Quartz64-b onboard memory (emmc) beepy 2 3,112 07-20-2023, 10:44 PM
Last Post: beepy
  crux-arm Quartz64 RK3566 (aarch64) mara 5 8,256 10-29-2022, 06:55 AM
  Ov5647 camera attached via csi to Quartz64 /Soquartz Randomuser 0 2,514 07-21-2022, 01:08 PM
Last Post: Randomuser
  Armbian on Quartz64 dieselnutjob 34 44,413 03-17-2022, 06:29 AM
