Manjaro Plasma busted
(11-22-2022, 05:20 AM)_radv_ Wrote: I couldn't get Libra Office to install at all.  The Discover (GUI package manager on the Pine Phone) keeps telling me "the PackageKit Daemon has crashed" almost anytime I try to download something. pacman won't execute to update or install, I assume because Discover is running.
ug.
There are usually problems like this with Plasma regardless of distro. I'm guessing that an update will fix it.
However I installed Manjaro Phosh and it appears to be working fine. The only Plasma that seems to work well
in my opinion is Postmarket.
Edit: Also once you have sorted the device out and it works - don't update it. Just leave it as is and you may have the best overall luck.
TESTED: Arch Plasma, Arch Phosh , Manjaro Phosh, Manjaro Plasma
Fedora, Mobian, Postmarket Plasma, Postmarket Phosh, Kali, SXMO.
Manjaro Plasma busted - by Chief - 11-12-2022, 09:00 PM
RE: Manjaro Plasma busted - by _radv_ - 11-22-2022, 05:20 AM
RE: Manjaro Plasma busted - by Chief - 11-22-2022, 05:00 PM
  what is wrong with KDE plasma beta15 RC4? Uturn 8 1,548 10-02-2023, 05:07 AM
Last Post: Uturn
  Manjaro: Settings doesnt open nbh 0 576 09-24-2023, 05:25 PM
Last Post: nbh
  Can't get ring on Manjaro Pine Phone thorensjubilee 12 3,389 06-09-2023, 04:40 AM
Last Post: thorensjubilee
  Is Manjaro ARM a Rolling Release? jojuma 4 1,563 05-10-2023, 09:27 PM
  Where Does Manjaro Phosh Store Its Custom Keystrokes? jakfish 0 796 04-25-2023, 09:49 AM
Last Post: jakfish
Exclamation My short experience with Manjaro Plasma Mobile anonymous 10 4,648 03-02-2023, 07:25 PM
  Can't install Manjaro thorensjubilee 1 1,004 02-09-2023, 08:17 AM
  Manjaro plasma-mobile Beta 13 Uturn 13 4,803 01-25-2023, 04:15 PM
  MMS workaround for users with separate APN (works atleast on Manjaro Phosh) alaraajavamma 0 1,055 10-10-2022, 12:53 PM
Last Post: alaraajavamma
  Disabling screen timeout for plasma mobile rp3 7 7,189 09-05-2022, 03:50 PM
Last Post: christev1
