When are we getting Geary back?
(11-03-2022, 06:10 PM)LibrePhoneUser Wrote:
(11-03-2022, 04:54 PM)mob Wrote: I have been expecting any geary reintroduction for days, then finaly moved to mutt. It is in the mobian repos, and is much more efficient and reliable than geary in the end. If you are not affraid of the terminal, you should definately have a try on it. Also, mutt supports gpg.
Thanks for the suggestion, but I mainly used Geary to check for whether clients have sent me any urgent messages (and I would then go to my laptop to answer). For such fast, read-only mailchecking, Geary with its touch interface was a lot more convenient than a keyboard-driven app like mutt.
So, here's hoping that Geary is reintroduced to Debian Testing soon.
Once installed on mobian, there is a mutt icon on the phone "desktop". Clicking on it starts mutt and automatically fetch new incoming mails. Then hitting the q key is enought to quit the client. Nothing crazy as compared to geary workflow regarding the usage you describe. It is also possible to setup a cron job to automatically check new incoming mails every x minutes (or even seconds if you like), there are lots of tutorials for that. I am not aware of any similar capability with geary (push notification ?). But I agree mutt is different from geary, it is just a reasonable workaround until any future update. Not that bad, it really worth a try Wink
RE: When are we getting Geary back? - by mob - 11-03-2022, 04:54 PM
RE: When are we getting Geary back? - by mob - 11-04-2022, 06:22 PM
RE: When are we getting Geary back? - by shulamy - 11-05-2022, 10:46 PM
RE: When are we getting Geary back? - by Anna - 11-20-2022, 04:40 AM
RE: When are we getting Geary back? - by Gumur - 11-20-2022, 08:36 AM
RE: When are we getting Geary back? - by wibble - 11-20-2022, 06:46 AM
RE: When are we getting Geary back? - by user641 - 11-20-2022, 11:27 AM
RE: When are we getting Geary back? - by Anna - 12-09-2022, 04:18 AM
  packages held back user641 7 5,486 09-18-2023, 03:05 PM
Last Post: diederik
  Wifi issue since last update and held back updates goku499 11 11,910 09-21-2022, 02:39 PM
Last Post: Katsujinken
  geary shulamy 2 3,137 09-10-2022, 03:01 AM
Last Post: shulamy
  How to move Firefox address bar back to top? Zebulon Walton 5 5,711 06-11-2022, 09:41 AM
Last Post: iwakura_lain
  Geary: can't write mail jsch 2 3,028 03-12-2022, 03:28 AM
Last Post: jsch
  Packages being kept back user641 2 3,434 02-08-2022, 05:34 PM
Last Post: user641
  Protonmail in Geary tombull 1 3,640 11-14-2021, 07:42 AM
Last Post: d-.-b
  need my usb tethering back HLing 12 15,192 08-02-2021, 10:13 AM
  Protonmail in geary r7s3TgmyQv2R3z 1 4,170 03-18-2021, 02:32 PM
Last Post: user12345
  Geary crashes during start after recent update p1trson 2 5,236 01-16-2021, 04:49 AM
Last Post: p1trson
