keyboard case charging but not typing
In the meantime, my second PPKB has stopped typing, just like the first. It appears to have happened after detaching / reattaching the phone to the keyboard case a few times.
But I returned to the old PPKB, which I had previously opened and exposed its mainboard and did the following:
  1. detached the phone from the PPKB
  2. soldered an USB connector on the mainboard USB contacts
  3. connected to the computer (`dmesg -ew` reported it being connected)
  4. used Megi's tools to flash the stock firmware via USB
  5. disconnected the USB from the computer (it's still soldered to the mainboard)
  6. reattached the phone to the PPKB
  7. reloaded the PPKB kernel module (this works instead of rebooting)
  8. PPKB did not work
HOWEVER, if I keep the USB plugged into the computer, while the PinePhone is attached to the keyboard, THE KEYS WORK. I don't know if flashing did anything (probably not). If I unplug the USB from the computer, the PPKB stops working. But if I plug the USB into the computer again THE PPKB START WORKING AGAIN.
So currently, I can type on the PPKB as long as its mainboard is hardwired to a USB connector and plugged into the computer  Undecided
I'm almost certain this had nothing to do with flashing. Resetting the MCU doesn't help either (either via I²C or via USB).
But it's almost certainly a software / firmware issue, because plugging the PPKB into the computer via USB makes it suddenly work again (after reloading the kernel module, but only once).
RE: keyboard case charging but not typing - by theResonant - 02-11-2024, 09:37 AM
  Case for Pinephone totilele 13 7,587 04-11-2024, 11:48 AM
Last Post: gramonyl
  Slip/Zippered Case for PP/KB? jakfish 0 306 03-03-2024, 04:55 PM
Last Post: jakfish
  Keyboard doesn't charge my phone no matter what, so can I charge my phone directly ragreenburg 3 10,522 01-14-2024, 03:34 PM
Last Post: acid andy
  I've added an I2C connector to the PP keyboard eugenr 0 455 11-26-2023, 07:24 AM
Last Post: eugenr
  Update the PinePhone keyboard driver to support missing characters? Peter Gamma 8 8,279 10-22-2023, 08:43 PM
Last Post: Peter Gamma
  key repeat with pinephone keyboard rotwang 0 479 10-22-2023, 03:39 PM
Last Post: rotwang
Exclamation USB mouse isn't working when a PP keyboard is attached? mikeb 3 1,293 10-21-2023, 08:21 PM
  Pinephone with mini keyboard, trackpad and large power bank? Peter Gamma 0 548 10-21-2023, 07:50 AM
  Which mini keyboard and mouse to choose for the PP? Peter Gamma 0 646 10-21-2023, 02:55 AM
  Use the Linux Console with the PinePhone Keyboard mburns 2 1,064 10-20-2023, 04:11 PM
Last Post: mburns
