No volume control after latest updates
More audio problems after updating over the weekend. Seemed to be OK initially, but after using the headset sound was pretty messed up even after rebooting. After disconnecting the headset, the phone would ring through the built-in earphone instead of the speaker. Audio not working on incoming calls, pick up a call and no sound. (OK on outgoing calls - I had to hang up on callers and call them back.) The phone apparently was acting in part as though the headset was still connected.
So it appears the pipewire setup still has some rough edges to work out. Fortunately I did a full image backup before doing the updates.
EDIT: Playing around with the phone a bit more and testing, it just seems to be shifting audio all over the place. For an incoming call, putting the speaker on and of diverts audio back to the phone's built-in earpiee. But then calling the phone again, ringing is routed to the earpiece instead of the speaker. Not sure if I'll restore an image backup from before this started happening or wait and see if subsequent updates fixes this stuff.
RE: No volume control after latest updates - by Zebulon Walton - 11-14-2022, 06:34 PM
  gnome-control-center: segmentation fault on startup jojuma 4 945 09-12-2023, 08:49 AM
Last Post: jojuma
  Problem with updates: Repository 'Debian bookworm' changed its 'non-free component' Anna 7 1,916 08-31-2023, 12:38 PM
Last Post: vusra
  Haven't seen updates in a while Zebulon Walton 3 1,134 06-24-2023, 04:29 PM
Exclamation Impossible to login since the latest update anonymous 12 3,923 02-26-2023, 01:01 PM
Last Post: anonymous
Exclamation The latest update of eg25-manager seems to cause frequent disconnections anonymous 12 4,033 11-28-2022, 03:30 PM
  [Fixed] Phosh crashes frequently after latest updates arno_nuehm 20 8,366 10-14-2022, 05:38 PM
Last Post: Krafter
  Latest Reliable Mobian Build Confirmation Thread Katsujinken 5 2,516 09-27-2022, 08:41 AM
Last Post: Katsujinken
  Wifi issue since last update and held back updates goku499 11 5,003 09-21-2022, 02:39 PM
  Loving latest Mobian Update drh 11 4,784 08-22-2022, 12:19 PM
  Pinephone incoming call / SMS notification no ringing / notification volume dcinoz 3 2,747 06-02-2022, 07:16 AM
Last Post: arkadione
