08-07-2016, 02:10 PM
(This post was last modified: 08-07-2016, 02:17 PM by blackt1ger.)
(07-13-2016, 07:22 PM)jodybrown99 Wrote: is the camera module supposed to fit into the slot in the lcd panel? it's a bit big, and does not fit. see picture.
https://imgur.com/uiJQq5s
Yeah, same here. Absolutely crazy. Wait till you try to mount the LCD in the playbox enclosure. The cables aren't long enough.
The sensor is 8.5 mm and the hole is 6.7...... Only thing you can do is cut the walls and glue it in.
