phone does not ring (when sleeping)
(10-07-2022, 04:19 AM)d-.-b Wrote:
(09-25-2022, 11:34 AM)jsch Wrote: My phone (OG PP) is no longer ringing reliable.
If the pone is already up (awake), then there is not issue perceived.
But if it is sleeping, then it it seldom ringing if called. The phone is waking up, hence I don't assume an issue w/ cell or modem.
I tried to tweak one parameter from eg25-manager, not sure if this is the right approach.
The line
{ cmd = "QCFG", subcmd = "urc/ri/ring", expect = "\"pulse\",120,1000,5000,\"off\",1" },
in /usr/share/eg25-manager/pine64,pinephone-1.2.toml
was changed to
{ cmd = "QCFG", subcmd = "urc/ri/ring", expect = "\"pulse\",120,1000,5000,\"off\",3" },
which allows it to ring three times.
I also got problems like this. When receiving a call now it only vibrate. No more ring sound. In deep sleep and on Phosh dashboard. Also, when phone is reboot, speaker sound bar is always at the lowest (like mute) and the sound buttons on the side not working. Anybody got a fix for that? Mobian on PP 32gb on SD card.
Thanks all!
I am quite sure that this related to Phosh or Phoc crash. I noticed that after Phosh 0.20 (version with swiping gestures) it crashes quite a lot - this is allready fixed on more recent builds but I think in Mobian it is still 0.20 right?
So if you can check is the caller hearing alert tones or "phone is not reachable" messages (or similar)? If he/she is hearing alert tones (beep - beep - beep) it is not "modem related".
When Phosh crashes it also crashes Pulseaudio and the lower part of your issue sounds like that. Vibration works but sound not.
phone does not ring (when sleeping) - by jsch - 09-25-2022, 11:34 AM
RE: phone does not ring (when sleeping) - by alaraajavamma - 10-07-2022, 08:08 AM
  MATE on pine phone user641 6 7,055 05-05-2022, 09:44 AM
  Phone mic isn't working at all D347h 2 3,492 01-26-2022, 07:34 AM
Last Post: D347h
  Screen/display gets switched on by itself / Phone wakes up from suspend Anna 5 7,103 01-04-2022, 01:24 PM
Last Post: pothos
  Block Phone Numbers? MarkF 6 8,325 12-02-2021, 08:26 AM
Last Post: Smeegle
  Phone suddenly unusable TRS-80 6 6,254 11-19-2021, 09:46 AM
Last Post: TRS-80
  Deep sleep shutdown the phone bitsandnumbers 19 21,786 10-22-2021, 07:04 AM
Last Post: kqlnut
  phone call using built it app will not go to bluetooth motox6 3 5,622 06-28-2021, 11:03 AM
Last Post: wibble
  audio quality on phone Rainer 0 2,143 05-28-2021, 09:25 AM
Last Post: Rainer
  Mobian: 2 week as main phone steves 10 18,339 05-18-2021, 11:55 AM
Last Post: vortex
  Bluetooth audio stalling (maybe the whole phone) motox6 1 2,940 05-18-2021, 10:15 AM
Last Post: wibble
