[Fixed] Phosh crashes frequently after latest updates
If you want to get updates run again, you have to downgrade three other packages:
wget https://repo.ialab.dsu.edu/debian/pool/main/g/gobject-introspection/libgirepository-1.0-1_1.73.0%2Bds-1_arm64.deb https://repo.ialab.dsu.edu/debian/pool/main/g/gobject-introspection/gir1.2-glib-2.0_1.73.0%2Bds-1_arm64.deb https://repo.ialab.dsu.edu/debian/pool/main/g/gobject-introspection/gir1.2-freedesktop_1.73.0%2Bds-1_arm64.deb
sudo dpkg -i libgirepository-1.0-1_1.73.0+ds-1_arm64.deb gir1.2-glib-2.0_1.73.0+ds-1_arm64.deb gir1.2-freedesktop_1.73.0%2Bds-1_arm64.deb
sudo apt-mark hold libgirepository-1.0-1 gir1.2-glib-2.0 gir1.2-freedesktop
After this, updates should work again...
RE: [Temporarily Fixed] Phosh crashes frequently after latest updates - by arno_nuehm - 09-22-2022, 03:30 PM
  mobian phosh on screen keyboard not popping up for Chromium/Electron apps grump_fiddle_reinstall 1 2,962 01-15-2025, 08:08 PM
  Auto start application on Phosh login Zebulon Walton 8 9,037 10-14-2023, 06:29 AM
Last Post: alaraajavamma
  No volume control after latest updates Zebulon Walton 19 15,589 09-08-2023, 08:28 AM
Last Post: jessencan
  Problem with updates: Repository 'Debian bookworm' changed its 'non-free component' Anna 7 11,792 08-31-2023, 12:38 PM
Last Post: vusra
  Haven't seen updates in a while Zebulon Walton 3 3,686 06-24-2023, 04:29 PM
  Using sway along phosh fdlamotte 2 5,087 05-11-2023, 04:24 PM
Last Post: kabouik
Exclamation Impossible to login since the latest update anonymous 12 11,693 02-26-2023, 01:01 PM
Last Post: anonymous
  Mobian + phosh firefox ublock and other overlays display bugs tuxcall 3 3,831 02-24-2023, 12:11 AM
Last Post: nexion
Exclamation The latest update of eg25-manager seems to cause frequent disconnections anonymous 12 10,298 11-28-2022, 03:30 PM
  Latest Reliable Mobian Build Confirmation Thread Katsujinken 5 5,760 09-27-2022, 08:41 AM
Last Post: Katsujinken
