[Fixed] Phosh crashes frequently after latest updates
I am having the same but on PMOS Stable which use to be "safe choice".
What I am writing below are just my just my thoughts - certainly not entirely true
I think this is the issue:
https://gitlab.gnome.org/World/Phosh/phoc/-/issues/300
Or atleast Phosh is restarting many many times a day and the biggest problem in that every Phosh/Phoc restart makes calls and sound unusable but it is hard to notice.
Meaning that you are "online" but if someone calls you PP does not see it. The sound doesn't work either (but it is really hard to notice because it works somehow).
And eventually this also crashes the modem, but you have to start using the device.
I think someone found out that restarting Phosh/Phoc (I don't know which or both?) will restart also Pulseaudio and Pulseaudio did not crash in the first place so there is issue where you have two active Pulseaudio instances and none of them works. Maybe it is the same with Calls?
RE: EDIT: Phosh crashes frequently after latest updates (important - don't update!) - by alaraajavamma - 09-22-2022, 09:13 AM
  mobian phosh on screen keyboard not popping up for Chromium/Electron apps grump_fiddle_reinstall 1 2,962 01-15-2025, 08:08 PM
  Auto start application on Phosh login Zebulon Walton 8 9,037 10-14-2023, 06:29 AM
Last Post: alaraajavamma
  No volume control after latest updates Zebulon Walton 19 15,589 09-08-2023, 08:28 AM
Last Post: jessencan
  Problem with updates: Repository 'Debian bookworm' changed its 'non-free component' Anna 7 11,792 08-31-2023, 12:38 PM
Last Post: vusra
  Haven't seen updates in a while Zebulon Walton 3 3,686 06-24-2023, 04:29 PM
  Using sway along phosh fdlamotte 2 5,087 05-11-2023, 04:24 PM
Last Post: kabouik
Exclamation Impossible to login since the latest update anonymous 12 11,693 02-26-2023, 01:01 PM
Last Post: anonymous
  Mobian + phosh firefox ublock and other overlays display bugs tuxcall 3 3,831 02-24-2023, 12:11 AM
Last Post: nexion
Exclamation The latest update of eg25-manager seems to cause frequent disconnections anonymous 12 10,279 11-28-2022, 03:30 PM
  Latest Reliable Mobian Build Confirmation Thread Katsujinken 5 5,760 09-27-2022, 08:41 AM
Last Post: Katsujinken
