Wifi issue since last update and held back updates
(09-19-2022, 04:08 PM)Katsujinken Wrote:
(09-19-2022, 10:18 AM)jsch Wrote:
(09-19-2022, 09:34 AM)Katsujinken Wrote:
(09-10-2022, 01:38 PM)tcharlss Wrote:
(09-08-2022, 03:35 AM)user641 Wrote: I am having similar problems, my date was stucked at august 27th, I fixed with ntp but can't reach any website, including the debian and mobian repos. But my wifi works fine, I can run apt update && apt upgrade using tor
I Was having the exact same problem: after a recent update, wifi was on seemed to be connected, but there was no internet connectivity.
Luckily the solution in this thread worked for me: https://forum.pine64.org/showthread.php?tid=17288
I tried the solution in the thread provided. I posted there that it didn't work but no one replied with alternate solutions. Is there anything that can be suggested in regards to resolving this issue. If I have to do a full reinstall that's fine but can anyone confirm that's all that can be done or what?
It might help if you share the content of your /etc/resolv.conf
It might help if you share the filename your /etc/resolv.conf is pointing to (readlink /etc/resolv.conf)
When I enter...
sudo ln -sf /run/NetworkManager/resolv.conf /etc/resolv.conf
I get no confirmation from terminal one way or the other about what it does. It just goes right back to the command prompt.
Nice, and fun, info. Thanks for sharing! :-)
RE: Wifi issue since last update and held back updates - by drh - 09-21-2022, 05:11 AM
  trixie update poll questions suggestions j_s 5 450 10-22-2025, 07:14 AM
Last Post: anonymous
  Pinephone seems tobe using 4G data instead of Wifi data grump_fiddle_reinstall 7 4,914 02-20-2025, 02:47 PM
Last Post: puffchumpy
  New keyboard issue sandspur 30 29,593 01-13-2025, 01:37 AM
  how to update mobian over tor vusra 14 15,299 12-04-2024, 07:01 PM
Last Post: vusra
  packages held back user641 7 5,464 09-18-2023, 03:05 PM
Last Post: diederik
  No volume control after latest updates Zebulon Walton 19 15,494 09-08-2023, 08:28 AM
Last Post: jessencan
  Problem with updates: Repository 'Debian bookworm' changed its 'non-free component' Anna 7 11,747 08-31-2023, 12:38 PM
Last Post: vusra
  reset wifi hardware/driver when it dies through console on pp? tuxcall 4 4,387 07-18-2023, 08:54 AM
Last Post: junelung
  GStreamer Camera Issue (Unsupported pixformat: 0x56595559 with mbus code: 0x3001) sog8b 1 2,568 07-17-2023, 01:49 AM
Last Post: junelung
  Haven't seen updates in a while Zebulon Walton 3 3,668 06-24-2023, 04:29 PM
