Fedora Workstation (36) on Pinebook Pro
(08-29-2022, 11:09 PM)u974615 Wrote:
(08-27-2022, 03:06 PM)petersen77 Wrote: Check the firmware, copy all files from Manjaro /usr/lib/firmware. I guess some firmware files are missing. I managed to get void Linux wifi working that way.
Gesendet von meinem RMX3085 mit Tapatalk
Tried this. No change.  Wifi still not working.  Oddly, bluetooth is working.
(08-27-2022, 05:56 PM)pjsf Wrote:
(08-26-2022, 11:18 PM)u974615 Wrote: I have been able to successfully flash TOW-Boot to the SPI, and create a bootable microSDXC (Video speed class 10 ) image of Fedora Workstation 36 for aarch64.
I can see why one would use an NVMe SS drive verses eMMC with Fedora Workstation for ARM64.
How did you get the brcmfmac Wifi driver working?  I installed the one linked in the blog post, but no success.
What he said, or use dmesg to see what firmware file is failing to load and just copy that one form either manjaro or another source to the location in the error message, them either rmmod/modprobe or reboot.
I never tried fedora from emmc, it was way too slow on sd though but fairly smooth on nvme.
Neither dmesg nor journalctl have anything about brcmfmac43456.  I feel like there should be a kernel module of wl, but don't even see that failing to load.
I was hoping to have Wifi working, before installing to the eMMC.
did you use dnf to install the rpm or software-center or something else?
so if you do lsmod do you see brcrmfmac loaded? I was actually misrembering , the only firmware I needed to find was BCM4345CS.hcd for the bluetooth support.
RE: Fedora Workstation (36) on Pinebook Pro - by pjsf - 08-30-2022, 09:50 PM
  Debian on Pinebook Pro u974615 8 444 03-22-2024, 03:57 PM
Last Post: u974615
  Fedora 37 installation gswatkins 16 5,527 03-16-2024, 03:09 PM
Last Post: michel_luc
  Pinebook Pro upgrading from the factory image yamsoup 12 1,118 02-22-2024, 04:02 PM
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 1,917 12-13-2023, 07:22 PM
Last Post: trillobite
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 6 1,979 12-11-2023, 03:47 AM
Last Post: calinb
  Gentoo on Pinebook Pro RELEASE jannik2099 54 86,635 12-08-2023, 11:25 PM
  Boot Order in Pinebook Pro food 8 993 11-23-2023, 07:37 AM
  Fedora 36 -> 37 upgrade kills system tydeman 0 370 10-28-2023, 09:53 AM
Last Post: tydeman
  PineBook Pro seems to go to deep sleep, but doesn't wake up pogo 11 4,925 08-31-2023, 04:20 PM
Last Post: TRS-80
  Would a Pinebook Pro be good for a Linux newbie? cassado10 6 1,325 08-08-2023, 04:58 AM
Last Post: moobythegoldensock
