The settings icon disappeared
#35
(08-22-2022, 01:33 PM)biketool Wrote:
(08-22-2022, 12:24 PM)grump_fiddle_reinstall Wrote: In addition you can no longer just tap right at the top to get the drawer with Wifi/4G etc and volume and brightness controls to slide down. You now have to slide it down  Dodgy
"Success should not be measured by the amount of change inflicted on others."
I will shuffle off and be grumpy somewhere else for a while.
I guess I am lucky that I found shortly before I was about to buy two more PinePhones. Now I will wait to see how my experiments with PostmarketOS go before I spend any more money.
you could give Maemo Leste a SD boot try in the meantime.
Interestingly the change for the app drawer at the bottom, from a tap to activate it to a slide does actually solve one problem. With tap to activate it is quite easy to hit the drawer causing it to slide up while trying to hit the spacebar whilst typing some text. Which I find mildly annoying. Now that the drawer has to slide up from the bottom missing the spacebar is no longer a problem.
However, currently switching between PinePhone and a Pro (both with Mobian) the former with the tap behaviour and the latter with the slide behaviours is mucking up my muscle memory.
I am aware of Maemo Leste but I'd actually like something with the XFCE desktop at the moment. I looked at UB Ports briefly but there are still some things that don't work with the PPPro.
The search for the perfect PP(Pro) OS/GUI, like the search for the perfect tent is an eternal and ongoing project.
The settings icon disappeared - by kubussz - 08-22-2022, 07:46 AM
RE: The settings icon disappeared - by Eugo - 08-22-2022, 08:02 AM
RE: The settings icon disappeared - by biketool - 08-22-2022, 12:13 PM
RE: The settings icon disappeared - by biketool - 08-22-2022, 01:33 PM
RE: The settings icon disappeared - by grump_fiddle_reinstall - 11-15-2022, 10:56 AM
>> - by ichbins - 08-23-2022, 01:31 AM
RE: The settings icon disappeared - by Gumur - 08-24-2022, 09:26 AM
RE: The settings icon disappeared - by dante404 - 08-24-2022, 11:57 AM
RE: The settings icon disappeared - by biketool - 08-24-2022, 12:05 PM
RE: The settings icon disappeared - by Gumur - 08-24-2022, 02:27 PM
RE: The settings icon disappeared - by biketool - 08-25-2022, 04:49 AM
RE: The settings icon disappeared - by Gumur - 08-26-2022, 02:04 AM
RE: The settings icon disappeared - by Flin - 08-29-2022, 03:44 PM
RE: The settings icon disappeared - by dante404 - 08-30-2022, 03:44 AM
RE: The settings icon disappeared - by Flin - 08-30-2022, 06:17 AM
RE: The settings icon disappeared - by dante404 - 08-30-2022, 06:54 AM
RE: The settings icon disappeared - by dante404 - 08-30-2022, 11:25 AM
RE: The settings icon disappeared - by Anna - 09-29-2022, 12:52 PM
RE: The settings icon disappeared - by treebeard - 09-30-2022, 08:21 AM
RE: The settings icon disappeared - by Anna - 10-01-2022, 10:51 AM
RE: The settings icon disappeared - by treebeard - 10-01-2022, 02:18 PM
RE: The settings icon disappeared - by Anna - 10-02-2022, 03:46 AM
RE: The settings icon disappeared - by biketool - 08-31-2022, 03:48 AM
RE: The settings icon disappeared - by Flin - 08-31-2022, 05:59 AM
RE: The settings icon disappeared - by dante404 - 09-01-2022, 01:15 AM
RE: The settings icon disappeared - by Flin - 09-01-2022, 05:58 AM
RE: The settings icon disappeared - by anonymous - 09-02-2022, 01:03 PM
RE: The settings icon disappeared - by Anna - 09-30-2022, 05:46 AM
  icon keyboard chris_02 4 4,189 01-14-2025, 02:49 AM
  MMS Carrier Settings biketool 0 1,206 10-20-2024, 09:19 AM
  APN settings not working with new operator SIM card user641 1 2,510 03-01-2023, 04:43 PM
Last Post: anonymous
  Exclamation point in cellular icon after update Zebulon Walton 8 8,876 06-22-2022, 05:57 PM
Last Post: albafrati
  Disappearing Settings GUI sandspur 4 5,349 04-09-2022, 04:49 AM
Last Post: sandspur
  lost settings icon from screen kubussz 3 4,610 02-17-2022, 09:26 AM
Last Post: beretta
  Disappeared one icon kubussz 0 1,547 02-03-2022, 11:41 AM
Last Post: kubussz
  How to switch off a app icon from list pinephone 6 8,243 05-14-2021, 02:38 AM
Last Post: pajux
  Desktop Entry icon not appearing: how to diagnose? Saliency 6 8,383 03-15-2021, 05:49 AM
Last Post: kqlnut
  lost settings icon from screen bobblestiltskin 2 4,754 11-19-2020, 01:07 PM
Last Post: bobblestiltskin
