Pinephone craches after each call
This happens almost every time a call is received or after a call is made. After a received call in the sound settings you might notice "dummy output". in most cases the phone must be rebooted. Other times you might see different settings such as default but the mic no longer responds. In that case you can log out and then log back in. The mic may work again. Saves a bit of time.
Arch Linux Phosh.
Pinephone craches after each call - by neithan76 - 07-26-2022, 08:21 PM
RE: Pinephone craches after each call - by acrux - 07-27-2022, 04:52 AM
RE: Pinephone craches after each call - by Chief - 07-29-2022, 11:47 AM
  New PinePhone user issues greenpineuser 8 7,046 12-19-2024, 09:47 PM
Last Post: emilianojay
  PinePhone Beta Edition will not boot from MicroSD card Timothy_Ecc 10 17,745 10-04-2024, 12:01 AM
Last Post: spazz
  Pinephone with KDE plasma - Battery drain when phone is not used Daniello 1 3,307 07-03-2024, 08:38 PM
  link for supported pinephone os manjharo et all penguins_rule 3 4,031 05-09-2024, 03:02 AM
Last Post: Eugo
  systemic issue pinephone penguins_rule 3 4,283 04-02-2024, 11:52 AM
  new PinePhone upgrade issue WhiteHexagon 5 6,880 05-09-2023, 04:09 PM
Last Post: WhiteHexagon
  Can't add micro SD card to Pinephone thorensjubilee 7 7,926 02-27-2023, 10:21 AM
Last Post: mikehenson
  Pinephone Freeze kmsgli 14 17,607 02-04-2023, 08:35 PM
Last Post: Westslope
  Unable to hear caller or speak after answering a call danimations 5 8,092 11-01-2022, 02:06 PM
Last Post: X0X0X0X0X0
  Weird call... Eugo 3 5,297 09-15-2022, 11:20 PM
Last Post: Eugo
