New SD card won't auto-mount, will only mount as read-only
I just got a 256gb, off-brand MicroSD card (it's actually Onn brand, which is a Walmart generic brand). Anyway, I formatted it on my computer, and everything seemed fine. But when I put it into my Pinephone, it won't mount. I can only mount it like so:
sudo mount -t ext4 -o ro /dev/mmcblk0p1 /storage/0000-0000/;
And if i put 'rw', it won't mount. It says 'bad superblock'. This is no matter how many times I reformat, if I recreate the partition table, If I disable journalling. I have even formatted it from inside the pinephone and it won't mount. Does anyone know what I can do to make my card auto-mount, and make it writable?
New SD card won't auto-mount, will only mount as read-only - by 3x5co - 07-15-2022, 07:57 PM
  Screen auto-rotation sensitivity mdk 0 1,764 12-26-2023, 06:08 AM
Last Post: mdk
  Auto start application on Phosh login Zebulon Walton 8 8,992 10-14-2023, 06:29 AM
Last Post: alaraajavamma
  APN settings not working with new operator SIM card user641 1 2,516 03-01-2023, 04:43 PM
Last Post: anonymous
  What does handle SD card automount? mdk 1 2,233 01-29-2023, 03:15 AM
Last Post: mdk
  Apps and SD Card biketool 2 3,480 03-06-2022, 09:47 AM
  How to flash a µSD-Card with Balena Etcher walter1950 1 2,457 01-22-2022, 02:06 AM
Last Post: bcnaz
  How to insert a SIM-Card and/or a µSD-Card walter1950 0 1,783 01-21-2022, 02:46 PM
Last Post: walter1950
  When I set SD card as /home, PP can't complete boot nelstomlinson 4 5,051 12-27-2021, 03:06 PM
Last Post: nelstomlinson
Question How to Save Read Only Files, Questions on Location lovepine88 8 12,679 06-12-2021, 06:08 PM
Last Post: ryo
  Unable to turn off auto brightness at times motox6 0 1,966 05-05-2021, 07:56 PM
Last Post: motox6
