Pine64+ 1GB Ethernet Port spec
Has the specifications of the Ethernet port on the Pine64+ 1GB changed?  According to the shop its only 10/100M.
The 1G Ethernet on the Pine64 is one of the main features I needed.  I'm not happy that I have to connect it to a 100M switch to get it to work.  I see from other post its possible to force the Pine64+ to 100M, so at least I don't need two routers now.  Not that I'm using the Pine64+ at the moment.  I bought a Banana Pi M1, which is great, especially with the proper SATA port (i.e., not USB to SATA like the Orange Pi or Banana Pi M3).
Pine64+ 1GB Ethernet Port spec - by ecotack - 07-08-2016, 06:07 AM
RE: Pine64+ 1GB Ethernet Port spec - by ecotack - 08-03-2016, 03:28 AM
RE: Pine64+ 1GB Ethernet Port spec - by pfeerick - 08-19-2016, 02:37 AM
RE: Pine64+ 1GB Ethernet Port spec - by pfeerick - 08-19-2016, 09:07 PM
RE: Pine64+ 1GB Ethernet Port spec - by tllim - 08-19-2016, 05:42 PM
RE: Pine64+ 1GB Ethernet Port spec - by pfeerick - 08-20-2016, 09:28 PM
  Ethernet port down afert 1 day jeda 0 597 11-12-2022, 06:48 AM
Last Post: jeda
  Ethernet --> Causing boot loop podtofs 3 5,224 05-16-2017, 03:41 AM
Last Post: m17
  GbE Ethernet Port Issue Data Gathering Statistics Intel MarkHaysHarris777 19 24,171 01-17-2017, 01:17 AM
Last Post: DrunkTank
  What will it take to get the Ethernet port working? clarkss12 10 16,091 10-17-2016, 03:42 PM
Last Post: waldo
  Ethernet Slow Download Ascotg 89 110,886 09-08-2016, 01:50 PM
Last Post: MarkHaysHarris777
Question no permanent MAC address? need it to give Pine64 a reserved IP. faddah 14 22,850 08-24-2016, 03:25 PM
  If you have had difficulty with the GbE ethernet please take the poll MarkHaysHarris777 0 2,344 08-17-2016, 05:44 PM
  Ethernet works on Arch Linux. Nothing elese pfunk237 4 6,012 07-23-2016, 03:07 PM
Last Post: SuperArmySoldiers
