Manjaro PBP stable update 2022-06-19 bricked
Long press the power button to shut down, and then prepare the native default system, preferably the image of the latest version of Manjaro arm KDE, write it to the SD card and insert it into the SD card slot. At the same time, put the image of the system into a USB flash disk and insert it into the notebook.
Then, remove the back cover, press and hold the recovery key (one of the two small black cylinders) above the motherboard with your fingertips, and then press the power key. At this time, the screen flashes several times for a long time. After it is displayed normally, it will enter the SD card system. During startup setting, do not install the system. In the trial state, open the start button, find the manjaro arm flasher , open it, find the system image in the USB flash disk in the path, set the partition where the installation location EMMC is located, press start , and exit the flasher tool after running is completed。
Next, click the start button to shut down.
Then, unplug the USB flash disk and SD card and turn it on.
RE: Manjaro PBP stable update 2022-06-19 bricked - by wangyukunshan - 06-30-2022, 10:03 PM
  PulseAudio dropouts after Manjaro Testing 2025.07.26 update Dendrocalamus64 2 4,311 08-08-2025, 02:39 PM
Last Post: Dendrocalamus64
  pbp with manjaro arm seems to not find any hardware[no wifi, blutooth or battery] frank_philip 4 5,862 03-15-2025, 01:47 AM
Last Post: frank_philip
  new manjaro install: wlan0 stuck in setting network address zkajdan 5 6,979 02-19-2025, 12:49 PM
Last Post: zkajdan
  Manjaro Sway Theme Broken Eighty8 1 3,931 03-08-2024, 08:41 AM
Exclamation 'failed to open panfrost' after system update using archarm Puckla 1 3,980 03-01-2024, 06:46 PM
Last Post: Puckla
Question Manjaro with Full Disk Encryption and GRUB dumetrulo 1 6,443 02-02-2024, 02:45 AM
Last Post: frankkinney
  Manjaro network problem late 2023 acruhl 1 3,804 01-19-2024, 11:32 PM
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 9,973 12-13-2023, 07:22 PM
Last Post: trillobite
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 6 11,135 12-11-2023, 03:47 AM
Last Post: calinb
  Manjaro 20.04 not loading from SD (with Manjaro on eMMC) zaius 1 3,322 12-07-2023, 03:11 PM
