C4 Labs Pine 64 Cases (Standard & LCD)
#95
(07-14-2017, 01:01 AM)zer0sig Wrote: After a week I definitely notice the fan sound a bit more, but that's only if the TV and A/C are off. It's quieter than both, and my guess is it isn't necessary to function though I will probably try to stress test the PINE64 to see if I can get it hot enough to be a concern. Still very happy- it is attractive, affordable and pretty easy to assemble. As I'm starting to get hooked on these PINE devices, I could see getting more of these cases in the future.
Are you running the fan at full speed ?
... if you drive the fan via 2N2222 transistor using a pwm signal ( 5v switched on|off with a duty cycle of 80% ) the fan will spin slower and almost completely silently;  I wrote a script ( python ) which does this with software pwm , and has a mechanism ( signals ) that allow switching the motor between high and low speed under program control;  if it gets above a certain temp, or if you just want to, the fan can be switched to high speed for a while.
See this link:
See this link also:
RE: The C4 Labs pine 64 case - by Ghost - 07-07-2016, 09:38 PM
RE: The C4 Labs pine 64 case - by Bluphire - 07-08-2016, 08:29 PM
RE: The C4 Labs pine 64 case - by Toriless - 12-20-2016, 07:13 AM
RE: The C4 Labs pine 64 case - by Bluphire - 07-08-2016, 09:30 PM
RE: The C4 Labs pine 64 case - by Dustin_C4Labs - 07-11-2016, 12:37 AM
RE: The C4 Labs pine 64 case - by Dustin_C4Labs - 07-12-2016, 03:22 PM
RE: The C4 Labs pine 64 case - by dkryder - 07-11-2016, 01:39 AM
RE: The C4 Labs pine 64 case - by dkryder - 07-11-2016, 07:49 AM
RE: The C4 Labs pine 64 case - by g_t_j - 07-11-2016, 11:05 AM
RE: The C4 Labs pine 64 case - by Bluphire - 07-11-2016, 11:53 AM
RE: The C4 Labs pine 64 case - by Dustin_C4Labs - 07-14-2016, 09:12 PM
RE: The C4 Labs pine 64 case - by Bluphire - 07-14-2016, 09:18 PM
RE: The C4 Labs pine 64 case - by tllim - 07-15-2016, 12:58 AM
RE: The C4 Labs pine 64 case - by Bluphire - 07-19-2016, 06:14 PM
RE: The C4 Labs pine 64 case - by CaptainZalo - 07-20-2016, 04:47 PM
RE: The C4 Labs pine 64 case - by Bluphire - 07-20-2016, 05:08 PM
RE: The C4 Labs pine 64 case - by CaptainZalo - 07-21-2016, 12:56 PM
RE: The C4 Labs pine 64 case - by lenwe33 - 07-21-2016, 02:41 PM
RE: The C4 Labs pine 64 case - by Bluphire - 07-21-2016, 02:53 PM
RE: The C4 Labs pine 64 case - by CaptainZalo - 07-21-2016, 03:41 PM
RE: The C4 Labs pine 64 case - by lenwe33 - 07-22-2016, 09:28 AM
RE: The C4 Labs pine 64 case - by CaptainZalo - 07-24-2016, 11:33 PM
RE: The C4 Labs pine 64 case - by montero65 - 08-16-2016, 11:30 AM
RE: The C4 Labs pine 64 case - by CaptainZalo - 08-18-2016, 02:36 PM
RE: The C4 Labs pine 64 case - by Bluphire - 08-19-2016, 11:29 AM
RE: The C4 Labs pine 64 case - by CaptainZalo - 08-19-2016, 03:40 PM
RE: The C4 Labs pine 64 case - by montero65 - 08-19-2016, 05:31 PM
RE: The C4 Labs pine 64 case - by Bluphire - 08-19-2016, 09:10 PM
RE: The C4 Labs pine 64 case - by UnixOutlaw - 08-25-2016, 01:36 AM
RE: The C4 Labs pine 64 case - by pspina3rd - 08-26-2016, 05:43 AM
RE: The C4 Labs pine 64 case - by pspina3rd - 08-26-2016, 06:37 AM
RE: The C4 Labs pine 64 case - by pspina3rd - 08-26-2016, 09:09 AM
RE: The C4 Labs pine 64 case - by Bluphire - 08-26-2016, 05:57 AM
RE: The C4 Labs pine 64 case - by pspina3rd - 08-29-2016, 02:27 PM
RE: The C4 Labs pine 64 case - by Bluphire - 08-29-2016, 02:37 PM
RE: The C4 Labs pine 64 case - by Bluphire - 08-30-2016, 01:46 PM
RE: The C4 Labs pine 64 case - by pspina3rd - 09-01-2016, 07:52 AM
RE: The C4 Labs pine 64 case - by UnixOutlaw - 09-04-2016, 10:16 PM
RE: The C4 Labs pine 64 case - by UnixOutlaw - 09-06-2016, 10:18 PM
RE: The C4 Labs pine 64 case - by pspina3rd - 09-08-2016, 06:45 AM
RE: The C4 Labs pine 64 case - by Bluphire - 09-08-2016, 10:14 AM
RE: The C4 Labs pine 64 case - by Bluphire - 09-08-2016, 11:44 AM
RE: The C4 Labs pine 64 case - by pspina3rd - 09-08-2016, 01:54 PM
RE: The C4 Labs pine 64 case - by Severian - 09-08-2016, 03:14 PM
RE: The C4 Labs pine 64 case - by Bluphire - 09-08-2016, 04:57 PM
RE: The C4 Labs pine 64 case - by Severian - 09-08-2016, 05:19 PM
RE: The C4 Labs pine 64 case - by Bluphire - 09-10-2016, 12:13 PM
RE: The C4 Labs pine 64 case - by Bluphire - 09-18-2016, 08:49 PM
RE: The C4 Labs pine 64 case - by MobileFusion - 09-20-2016, 01:57 AM
RE: The C4 Labs Pine 64 Case - by Bluphire - 09-21-2016, 08:11 AM
RE: The C4 Labs Pine 64 Case - by pspina3rd - 09-21-2016, 10:15 AM
RE: The C4 Labs Pine 64 Case - by MobileFusion - 09-22-2016, 02:16 AM
RE: The C4 Labs Pine 64 Case - by CaptainZalo - 09-22-2016, 05:04 AM
RE: The C4 Labs Pine 64 Case - by Bluphire - 09-22-2016, 01:29 PM
RE: The C4 Labs Pine 64 Case - by Bluphire - 09-22-2016, 07:30 PM
RE: C4 Labs Pine 64 Cases (Standard & LCD) - by MarkHaysHarris777 - 07-14-2017, 01:05 AM
  Clear case PIne 64 with VESA100 LIPO , RTC holder, and mini fan holes killor 6 11,388 08-05-2017, 07:15 AM
Last Post: killor
  New Pine 64 Screen Case from C4Labs Dustin_C4Labs 11 18,698 07-18-2017, 10:39 AM
Information Giving the Pine a trunk, a Playbox pedestal tommypine 7 9,956 07-16-2017, 01:51 AM
Last Post: selina3
  Official C4 Labs LCD Enclosure *UPDATED WITH ASSEMBLY VIDEO* Bluphire 12 24,608 01-06-2017, 03:15 AM
Last Post: Learnincurve
  Do Pine sell a tablet back cover? brucezepplin 4 7,692 12-20-2016, 08:24 AM
Last Post: Bluphire
  Pine 64 in a pine box :) sgjava 5 9,461 11-18-2016, 12:24 AM
Last Post: MarkHaysHarris777
  Suggestion for future cases from Pine evdboogerd 2 4,458 09-07-2016, 05:05 PM
Last Post: typerod
  LaserCut Pine Enclosure Macrois 10 12,960 08-31-2016, 01:24 PM
Last Post: Tarjei85
  Standard Mounting Standoffs from the Hardware Store MarkHaysHarris777 2 4,669 08-28-2016, 02:49 AM
Video Acrylic enclosure for PINE A64 killor 71 87,949 08-12-2016, 06:53 AM
Last Post: killor
