Lost my second display
(06-04-2022, 09:32 AM)user18130814200115 Wrote:
(06-04-2022, 09:20 AM)WEF Wrote: I am running the stock linux that came with the device.
Here is the output of the command:
linux
Right so that is "upstream" linux package. The "linux-pinebookpro" package is avaible in manjaro's core repo but it is an older version.
I believe the main manjaro linux kernel (the one you have) SHOULD work with your external display.
Check the pacman cache for an older version.
Otherwise, this repo: https://pacman.kiljan.org/archlinuxarm-pbp/os/aarch64/zameenContains linux-manjaro-5.18.1-3 which should work with e-DP1.
Yes I also used the same repo you mentioned and it has worked for me, I hope it will also work for him too. I was also searching for it and then found it in some other forum here.
Lost my second display - by WEF - 06-01-2022, 12:35 PM
RE: Lost my second display - by WEF - 06-04-2022, 09:20 AM
RE: Lost my second display - by shalish - 06-08-2022, 12:57 PM
RE: Lost my second display - by josmo - 08-18-2022, 07:53 AM
  PinebookPro Display Corrupts/Cuts Out Twig 5 2,115 06-11-2023, 07:59 AM
  PBP green LED works but blank display. frerebo 1 808 02-22-2023, 03:11 AM
  Issues with External Display After Recent Update reundo 0 1,337 11-18-2021, 06:37 PM
Last Post: reundo
  No Display on PBP PitCritter 2 2,225 09-04-2021, 12:05 AM
Last Post: lot378
  Pinebook Pro - Display cable broken? snokis 0 1,473 08-17-2021, 11:30 AM
Last Post: snokis
  pinebook pro dock display out mamboman777 0 1,471 07-29-2021, 10:41 AM
Last Post: mamboman777
  USB C dock with internal display mirrored to projector and one extended display jbrock 4 2,944 07-19-2021, 04:00 PM
Last Post: jbrock
  [split] U-Boot with NVMe support, keyboard & display working as400 83 80,836 01-27-2021, 12:48 AM
Last Post: as400
  No keyboard & trackpad leads to no display. RMA from the US. Free parts in Seattle BitterPine 4 8,337 12-30-2020, 06:14 AM
Last Post: BetteHoward
Exclamation Seemingly lost power permanently now /cry jimsurvak 2 3,011 11-16-2020, 06:22 PM
Last Post: jimsurvak
