New keyboard issue
#25
Has something similar occurred again with the keyboard drivers? My keyboard is still charging and supplying power to the phone but I can no longer type using it. I am having to use the on screen keyboard.
Running 6.1-sunxi64 kernel from the eMMC.
Edit I assume the keyboard failure is as a result of an update but I am not 100% sure. I did replace the logic board in my keyboard earlier this year which restored the unit to full working order (both charging and working as a keyboard).
Edit 2: the keyboard has just suddenly started working again of its own accord. I rebooted and then shutdown and booted again earlier this morning neither of which helped. So I have no idea what is going on.
Edit 3: and now it has stopped working again. I am shutting down and going to remove the PinePhone from the case.
Edit 4: the keyboard behaves in the same way with a PPPRo, power OK but no response when keys are pressed. So it seems more likely to be a hardware failure than a driver issue. Especially as the keyboard starting working momentarily earlier this morning.
New keyboard issue - by sandspur - 06-01-2022, 04:04 AM
RE: New keyboard issue - by zltpxqhp69o2 - 06-02-2022, 02:50 AM
RE: New keyboard issue - by sandspur - 06-02-2022, 05:47 AM
RE: New keyboard issue - by zltpxqhp69o2 - 06-03-2022, 04:27 AM
RE: New keyboard issue - by Brother Cadfael - 06-06-2022, 04:02 AM
RE: New keyboard issue - by MacarioMorenoUK - 06-07-2022, 02:36 AM
RE: New keyboard issue - by sandspur - 06-23-2022, 04:05 AM
RE: New keyboard issue - by zltpxqhp69o2 - 06-24-2022, 04:00 AM
RE: New keyboard issue - by zltpxqhp69o2 - 06-24-2022, 11:59 AM
RE: New keyboard issue - by Brother Cadfael - 07-01-2022, 08:03 AM
RE: New keyboard issue - by Brother Cadfael - 07-01-2022, 09:14 AM
RE: New keyboard issue - by Brother Cadfael - 07-06-2022, 02:55 PM
RE: New keyboard issue - by jojuma - 07-24-2022, 07:39 AM
RE: New keyboard issue - by jojuma - 07-30-2022, 04:33 AM
RE: New keyboard issue - by sandspur - 08-14-2022, 06:46 AM
RE: New keyboard issue - by grump_fiddle_reinstall - 09-02-2023, 02:09 AM
RE: New keyboard issue - by zltpxqhp69o2 - 09-02-2023, 06:11 AM
  icon keyboard chris_02 3 490 02-09-2024, 08:53 AM
Last Post: 3x5co
  Keyboard not popping up on QT apps 3x5co 1 288 02-08-2024, 11:45 PM
  Keyboard keeps disappearing the moment it's touched jojuma 1 550 10-29-2023, 08:34 AM
Last Post: walter1950
  GStreamer Camera Issue (Unsupported pixformat: 0x56595559 with mbus code: 0x3001) sog8b 1 1,239 07-17-2023, 01:49 AM
Last Post: junelung
  Unable to do initial setup of Weather due to keyboard LibrePhoneUser 2 1,151 07-07-2023, 03:29 AM
Last Post: jojuma
  Battery problem with a Pinephone keyboard and Mobian elode 2 2,255 12-22-2022, 07:10 PM
Last Post: acid andy
  Possible solutions to the battery draining issue? 3x5co 5 2,511 11-28-2022, 10:58 AM
Last Post: 3x5co
  Wifi issue since last update and held back updates goku499 11 5,474 09-21-2022, 02:39 PM
Last Post: Katsujinken
  Would creating a 2 row landscape keyboard be difficult? rp3 1 1,150 09-09-2022, 06:49 AM
Last Post: zetabeta
  Making a new keyboard layout Eugo 2 1,536 08-28-2022, 04:15 AM
Last Post: Eugo
