New keyboard issue
(06-01-2022, 04:04 AM)sandspur Wrote: After an update using the graphical application with Mobian my mechanical keyboard does not work. The on-screen keyboard does work, however.
One of the updated files had something to do with the keyboard.
If anyone has experienced the same problem and can offer a suggested fix please do so.
sandspur
lesser wizard
running Mobian bookworm updated 1 June 2022 at 0830 UTC approximately.
This was discussed in Matrix.  Here's a message from Undef on June 1st: Assuming the fix goes well, there should be a (completely untested) patched kernel in the build artefacts of https://gitlab.com/mobian1/devices/sunxi...equests/60 in about an hour if anyone with a keyboard (and the ability to revert the update) is willing to test it.
Somebody did test it and it worked for them, but I haven't checked for other updates on the situation.
New keyboard issue - by sandspur - 06-01-2022, 04:04 AM
RE: New keyboard issue - by zltpxqhp69o2 - 06-02-2022, 02:50 AM
RE: New keyboard issue - by sandspur - 06-02-2022, 05:47 AM
RE: New keyboard issue - by zltpxqhp69o2 - 06-03-2022, 04:27 AM
RE: New keyboard issue - by Brother Cadfael - 06-06-2022, 04:02 AM
RE: New keyboard issue - by MacarioMorenoUK - 06-07-2022, 02:36 AM
RE: New keyboard issue - by sandspur - 06-23-2022, 04:05 AM
RE: New keyboard issue - by zltpxqhp69o2 - 06-24-2022, 04:00 AM
RE: New keyboard issue - by zltpxqhp69o2 - 06-24-2022, 11:59 AM
RE: New keyboard issue - by Brother Cadfael - 07-01-2022, 08:03 AM
RE: New keyboard issue - by Brother Cadfael - 07-01-2022, 09:14 AM
RE: New keyboard issue - by Brother Cadfael - 07-06-2022, 02:55 PM
RE: New keyboard issue - by jojuma - 07-24-2022, 07:39 AM
RE: New keyboard issue - by jojuma - 07-30-2022, 04:33 AM
RE: New keyboard issue - by sandspur - 08-14-2022, 06:46 AM
RE: New keyboard issue - by zltpxqhp69o2 - 09-02-2023, 06:11 AM
  On-Screen Keyboard Arrow Keys biketool 10 5,309 03-27-2025, 03:03 PM
  mobian phosh on screen keyboard not popping up for Chromium/Electron apps grump_fiddle_reinstall 1 2,951 01-15-2025, 08:08 PM
  icon keyboard chris_02 4 4,199 01-14-2025, 02:49 AM
  Keyboard not popping up on QT apps 3x5co 1 2,301 02-08-2024, 11:45 PM
  Keyboard keeps disappearing the moment it's touched jojuma 1 2,127 10-29-2023, 08:34 AM
Last Post: walter1950
  GStreamer Camera Issue (Unsupported pixformat: 0x56595559 with mbus code: 0x3001) sog8b 1 2,568 07-17-2023, 01:49 AM
Last Post: junelung
  Unable to do initial setup of Weather due to keyboard LibrePhoneUser 2 2,981 07-07-2023, 03:29 AM
Last Post: jojuma
  Battery problem with a Pinephone keyboard and Mobian elode 2 4,267 12-22-2022, 07:10 PM
Last Post: acid andy
  Possible solutions to the battery draining issue? 3x5co 5 5,773 11-28-2022, 10:58 AM
Last Post: 3x5co
  Wifi issue since last update and held back updates goku499 11 11,838 09-21-2022, 02:39 PM
Last Post: Katsujinken
