New keyboard issue
(06-03-2022, 04:27 AM)zltpxqhp69o2 Wrote: True that — I run all the things off an SD card anyway.
Disappearance of keyboard from power sources and lack of keyboard functionality is in line with what I have observed with the kernel that misses the drivers.
If «sudo lsmod | grep kb151» finds nothing and «sudo modprobe kb151» says the module is not found, I think you can be pretty sure you have the software issue, which does not exclude a hardware issue but puts its chances to the baseline.
About Mobian just fixing things — the unstable kernel package might indeed end up being promoted to bookworm in some time. A week or two maybe? Or has almost enough time passed already anyway? Not sure if this topic would change the timing. Maybe report the bug in their tracker and post the link here?
I just updated mobian this morning, no change in the kernel and the keyboard is still not being seen by the PinePhone.
I flashed the mobian-phosh image from 20220116 to an SD card and after the the phone booted the keyboard started working. This iteration of the OS does not have seperate bars in Settings->Power so there is no information about the charge of the keyboard battery. However, on pressing the button on the right hand side of the keyboard the "charging" symbol appeared in the phone's battery icon. I'm assuming that this means that the keyboard battery is providing power to the phone.
Anyway, it seems to confirm that the current version of mobian (stable?) is broken and that it is not a hardware issue.
New keyboard issue - by sandspur - 06-01-2022, 04:04 AM
RE: New keyboard issue - by zltpxqhp69o2 - 06-02-2022, 02:50 AM
RE: New keyboard issue - by sandspur - 06-02-2022, 05:47 AM
RE: New keyboard issue - by zltpxqhp69o2 - 06-03-2022, 04:27 AM
RE: New keyboard issue - by grump_fiddle_reinstall - 06-06-2022, 03:04 AM
RE: New keyboard issue - by Brother Cadfael - 06-06-2022, 04:02 AM
RE: New keyboard issue - by MacarioMorenoUK - 06-07-2022, 02:36 AM
RE: New keyboard issue - by sandspur - 06-23-2022, 04:05 AM
RE: New keyboard issue - by zltpxqhp69o2 - 06-24-2022, 04:00 AM
RE: New keyboard issue - by zltpxqhp69o2 - 06-24-2022, 11:59 AM
RE: New keyboard issue - by Brother Cadfael - 07-01-2022, 08:03 AM
RE: New keyboard issue - by Brother Cadfael - 07-01-2022, 09:14 AM
RE: New keyboard issue - by Brother Cadfael - 07-06-2022, 02:55 PM
RE: New keyboard issue - by jojuma - 07-24-2022, 07:39 AM
RE: New keyboard issue - by jojuma - 07-30-2022, 04:33 AM
RE: New keyboard issue - by sandspur - 08-14-2022, 06:46 AM
RE: New keyboard issue - by zltpxqhp69o2 - 09-02-2023, 06:11 AM
  On-Screen Keyboard Arrow Keys biketool 10 5,309 03-27-2025, 03:03 PM
  mobian phosh on screen keyboard not popping up for Chromium/Electron apps grump_fiddle_reinstall 1 2,951 01-15-2025, 08:08 PM
  icon keyboard chris_02 4 4,199 01-14-2025, 02:49 AM
  Keyboard not popping up on QT apps 3x5co 1 2,301 02-08-2024, 11:45 PM
  Keyboard keeps disappearing the moment it's touched jojuma 1 2,127 10-29-2023, 08:34 AM
Last Post: walter1950
  GStreamer Camera Issue (Unsupported pixformat: 0x56595559 with mbus code: 0x3001) sog8b 1 2,568 07-17-2023, 01:49 AM
Last Post: junelung
  Unable to do initial setup of Weather due to keyboard LibrePhoneUser 2 2,981 07-07-2023, 03:29 AM
Last Post: jojuma
  Battery problem with a Pinephone keyboard and Mobian elode 2 4,267 12-22-2022, 07:10 PM
Last Post: acid andy
  Possible solutions to the battery draining issue? 3x5co 5 5,773 11-28-2022, 10:58 AM
Last Post: 3x5co
  Wifi issue since last update and held back updates goku499 11 11,838 09-21-2022, 02:39 PM
Last Post: Katsujinken
