New keyboard issue
(06-01-2022, 04:04 AM)sandspur Wrote: After an update using the graphical application with Mobian my mechanical keyboard does not work. The on-screen keyboard does work, however.
One of the updated files had something to do with the keyboard.
If anyone has experienced the same problem and can offer a suggested fix please do so.
sandspur
lesser wizard
running Mobian bookworm updated 1 June 2022 at 0830 UTC approximately.
I seem to have just experienced this problem. Although it could be a coincidental hardware failure due to the way the fault appeared.
I left the PinePhone on overnight, it stayed up which is normal with both the phone and keyboard battery at full charge. The phone was NOT charging overnight.
This morning the keyboard does not work and the battery is not seen under Settings->Power although the PinePhone shows charging when the charger is disconnected from the keyboard's USB C connector.
The rate at which the reported % power on the PinePhone decreases suggests that it might still be drawing some current from the keyboard. While the decrease is slower than a solo PinePhone it is decreasing at a much higher rate than when the keyboard was connected and working as it should.
I still have the last image I installed on the phone on my computer. So I will dig out a spare SD card over the weekend and make a fresh install with the old image before mucking about with the fixes above. The main image is on the internal storage so I would need to back that up before making significant changes to it.
New keyboard issue - by sandspur - 06-01-2022, 04:04 AM
RE: New keyboard issue - by zltpxqhp69o2 - 06-02-2022, 02:50 AM
RE: New keyboard issue - by sandspur - 06-02-2022, 05:47 AM
RE: New keyboard issue - by grump_fiddle_reinstall - 06-02-2022, 11:50 PM
RE: New keyboard issue - by zltpxqhp69o2 - 06-03-2022, 04:27 AM
RE: New keyboard issue - by Brother Cadfael - 06-06-2022, 04:02 AM
RE: New keyboard issue - by MacarioMorenoUK - 06-07-2022, 02:36 AM
RE: New keyboard issue - by sandspur - 06-23-2022, 04:05 AM
RE: New keyboard issue - by zltpxqhp69o2 - 06-24-2022, 04:00 AM
RE: New keyboard issue - by zltpxqhp69o2 - 06-24-2022, 11:59 AM
RE: New keyboard issue - by Brother Cadfael - 07-01-2022, 08:03 AM
RE: New keyboard issue - by Brother Cadfael - 07-01-2022, 09:14 AM
RE: New keyboard issue - by Brother Cadfael - 07-06-2022, 02:55 PM
RE: New keyboard issue - by jojuma - 07-24-2022, 07:39 AM
RE: New keyboard issue - by jojuma - 07-30-2022, 04:33 AM
RE: New keyboard issue - by sandspur - 08-14-2022, 06:46 AM
RE: New keyboard issue - by zltpxqhp69o2 - 09-02-2023, 06:11 AM
  Trixie - bring up the On Screen Keyboard manually. grump_fiddle_reinstall 0 439 12-23-2025, 04:34 AM
  On-Screen Keyboard Arrow Keys biketool 11 7,608 12-23-2025, 04:25 AM
  mobian phosh on screen keyboard not popping up for Chromium/Electron apps grump_fiddle_reinstall 1 3,545 01-15-2025, 08:08 PM
  icon keyboard chris_02 4 4,838 01-14-2025, 02:49 AM
  Keyboard not popping up on QT apps 3x5co 1 2,747 02-08-2024, 11:45 PM
  Keyboard keeps disappearing the moment it's touched jojuma 1 2,489 10-29-2023, 08:34 AM
Last Post: walter1950
  GStreamer Camera Issue (Unsupported pixformat: 0x56595559 with mbus code: 0x3001) sog8b 1 3,283 07-17-2023, 01:49 AM
Last Post: junelung
  Unable to do initial setup of Weather due to keyboard LibrePhoneUser 2 3,485 07-07-2023, 03:29 AM
Last Post: jojuma
  Battery problem with a Pinephone keyboard and Mobian elode 2 4,853 12-22-2022, 07:10 PM
Last Post: acid andy
  Possible solutions to the battery draining issue? 3x5co 5 6,723 11-28-2022, 10:58 AM
Last Post: 3x5co
