PinePhone Pro working on Lapdock using Arch Plasma
to also make things a little easier, for those using docks /  SSH or lapdocks  if you find the device goes into suspend mode while its attached to power....  there is a widget  that might work for you.
sourced from https://forum.pine64.org/showthread.php?tid=12909
I happened to long-press the desktop, and "Add Widgets" appeared
I pressed this, and tried adding the "Display Configuration" widget.
It had something called "Enable Presentation Mode", which I tried.
if instead your looking to change the timings then JasonG-FR in a post in the above mentioned thread explains what to change in the ~/.config/powermanagementprofilesrc file...
RE: PinePhone Pro working on Lapdock using Arch Plasma - by hockleyj - 05-25-2022, 05:58 PM
  "USB access to SD" disappeared on a Pinephone Pro jebez 0 1,888 06-19-2026, 06:40 PM
Last Post: jebez
Rainbow Let's get the PPP and Mobian working! Rsquared 0 840 06-15-2026, 12:01 AM
Last Post: Rsquared
  what stopped pinephone pro? heocb 1 2,325 01-14-2026, 09:56 AM
  PinePhone Pro: Camera App very laggy Martin87 3 6,708 08-22-2025, 11:23 PM
Last Post: teekay
  PinePhone Pro discontinued teekay 9 19,426 08-22-2025, 11:19 PM
Last Post: teekay
Exclamation Pinephone Pro wont boot to anything! Supervisor 5 4,745 08-18-2025, 06:15 PM
  Pinephone pro ee bricked? dennylee 3 3,673 07-22-2025, 12:06 AM
Last Post: Dendrocalamus64
  Full desktop Surfing and Absolute Privacy on the pinephone? Www 8 6,317 06-30-2025, 10:51 AM
  Backing up data on Pinephone Pro to hard disk, optical disk and flash? Www 4 4,425 06-29-2025, 02:46 PM
  Printing and scanning documents with pinephone? Www 4 4,575 06-29-2025, 11:48 AM
