Tow-boot problems and restoring uboot
Today I ran into issue #1 listed in the Mobian Wiki, where the boot process stops at a black screen.
https://wiki.mobian-project.org/doku.php?id=tow-boot
Holding in the power button resulted in the phone rebooting rather than powering off, where the cycle repeated. It took several tries to get Mobian booted up. Tried the reset button in the back and finally had to remove the battery even though that's not recommended. This was a real pain, so for now I'd like to go back to uboot which never seemed to have any problems.
Before installing tow-boot I took an image backup of the eMMC using jumpdrive. Obviously the entire image could be copied back to the eMMC, but would it be possible to just extract uboot from there and write it to the eMMC using dd? What is the offset and length of the uboot image?
Tow-boot problems and restoring uboot - by Zebulon Walton - 04-19-2022, 09:42 AM
  boot gets stuck shortly after disk decryption vortex 9 9,187 09-11-2024, 05:40 AM
Last Post: normangraves
  mobian installed to eMMC - how to install tow-boot grump_fiddle_reinstall 6 7,614 11-22-2023, 11:46 AM
Last Post: aLoop100o
  How to check if tow-boot is installed? jojuma 3 3,475 09-29-2023, 11:29 PM
  Mobian boot failed with zstd message after upgrade. Mahgue 0 1,808 09-01-2023, 11:29 AM
Last Post: Mahgue
  Stability problems with 6.1 kernel Zebulon Walton 9 6,959 05-12-2023, 08:09 AM
Last Post: zetabeta
  4G data on default startup / boot dcinoz 1 2,241 04-29-2023, 11:24 PM
Last Post: dcinoz
  PinePhone won't boot after software update jb2000 2 3,581 03-17-2023, 07:26 AM
  Boot log analyses -> GPU no regulator (mali) found freelectro 0 2,201 03-06-2023, 12:06 PM
Last Post: freelectro
  [solved] Black screen at boot time mdk 0 2,034 01-13-2023, 03:33 AM
Last Post: mdk
  No boot after upgrade: vibration, red LED, then 2 vibrations and yellow LED 3x5co 1 2,309 01-04-2023, 06:46 PM
Last Post: 3x5co
