Flashing with RF Connect
(04-27-2022, 06:00 AM)ITCactus Wrote:
(04-27-2022, 04:02 AM)ronaldheld Wrote: @ITCactus, I only see the about screen when I hold down the button.
keep holding. after about 7-10 seconds it should either reboot and display the pinecone (bootloader, if you still have it),
or resets (dark screen for a second) and display the watchface (in that case it could be a sign you have no bootloader).
I did what you said to do. I got a white or light green pinecone. It eventually changed colors and the firmware came up. But it was 1.8.0 not 1.9.0. I declined the validation, and after another boot reverted to 1.9.0. what is going on?
Flashing with RF Connect - by ronaldheld - 04-11-2022, 03:53 AM
RE: Flashing with RF Connect - by ITCactus - 04-11-2022, 04:58 AM
RE: Flashing with RF Connect - by ronaldheld - 04-22-2022, 03:44 AM
RE: Flashing with RF Connect - by ITCactus - 04-22-2022, 03:55 AM
RE: Flashing with RF Connect - by ronaldheld - 04-26-2022, 06:49 AM
RE: Flashing with RF Connect - by wibble - 04-26-2022, 07:23 AM
RE: Flashing with RF Connect - by ITCactus - 04-26-2022, 08:19 AM
RE: Flashing with RF Connect - by ronaldheld - 04-27-2022, 04:02 AM
RE: Flashing with RF Connect - by ITCactus - 04-27-2022, 06:00 AM
RE: Flashing with RF Connect - by ronaldheld - 04-27-2022, 03:21 PM
RE: Flashing with RF Connect - by ITCactus - 04-28-2022, 03:25 AM
RE: Flashing with RF Connect - by ronaldheld - 04-28-2022, 03:56 AM
RE: Flashing with RF Connect - by ITCactus - 04-28-2022, 04:27 AM
  Flashing chris.burmajster 2 1,394 03-24-2025, 06:18 PM
Last Post: chris.burmajster
  Connect to Google Fit on Android? Ccssid 0 1,786 12-24-2023, 09:06 AM
Last Post: Ccssid
  No Luck flashing WaspOS MadHatter 0 1,645 12-11-2023, 01:19 AM
Last Post: MadHatter
  Watchmate doesn't connect to PT anymore jojuma 1 2,523 02-07-2023, 02:43 AM
Last Post: azymohliad
  can anyone suggest their working Linux bluetooth USB dongles to connect to Pinetime? jahway603 4 5,268 07-27-2022, 07:38 PM
Last Post: jahway603
Question [question] how to restore PineTime to a factory state after flashing non-OTA/directly ITCactus 2 4,450 04-11-2022, 05:03 AM
Last Post: ITCactus
  Gadgetbridge vs RF Connect ronaldheld 2 4,122 03-30-2022, 06:14 AM
Last Post: danimations
Question Which companion apps work best for flashing firmware and pairing/syncing w/ Pinetime? danimations 0 2,790 03-28-2022, 08:22 PM
  PineTime re-connect to PInephone kmsgli 8 9,480 01-01-2022, 08:05 PM
Last Post: kmsgli
  BT WONT CONNECT mindwave 8 10,302 11-19-2021, 03:18 AM
Last Post: danielt
