Flashing with RF Connect
for me, the About screen on sealed PineTime shows "1.0.0". the same on bootloader screen with triangular pine (v 1.0.0).
unsealed one, where i accidentally flashed the app directly using SWD flasher, that overridden all the content (incl. bootloader, i guess), i have "0.0.0", and i can not reboot the PineTime or do an OTA update. therefore this topic has been created.
there is a Video showing what the InfiniTime 1.0.0 bootloader looks like
@ronaldheld, do you see exactly the same on rebooting PineTime?
regarding "ASTRO File Manager & Cleaner", just tried, and i can confirm some issue - for me Gadgetbridge app ends up with "element cannot be installed" when sharing the file for update. so i can not use that file manager for updates.
Away
Flashing with RF Connect - by ronaldheld - 04-11-2022, 03:53 AM
RE: Flashing with RF Connect - by ITCactus - 04-11-2022, 04:58 AM
RE: Flashing with RF Connect - by ronaldheld - 04-22-2022, 03:44 AM
RE: Flashing with RF Connect - by ITCactus - 04-22-2022, 03:55 AM
RE: Flashing with RF Connect - by ronaldheld - 04-26-2022, 06:49 AM
RE: Flashing with RF Connect - by wibble - 04-26-2022, 07:23 AM
RE: Flashing with RF Connect - by ITCactus - 04-26-2022, 08:19 AM
RE: Flashing with RF Connect - by ronaldheld - 04-27-2022, 04:02 AM
RE: Flashing with RF Connect - by ITCactus - 04-27-2022, 06:00 AM
RE: Flashing with RF Connect - by ronaldheld - 04-27-2022, 03:21 PM
RE: Flashing with RF Connect - by ITCactus - 04-28-2022, 03:25 AM
RE: Flashing with RF Connect - by ronaldheld - 04-28-2022, 03:56 AM
RE: Flashing with RF Connect - by ITCactus - 04-28-2022, 04:27 AM
  Flashing chris.burmajster 2 1,394 03-24-2025, 06:18 PM
Last Post: chris.burmajster
  Connect to Google Fit on Android? Ccssid 0 1,786 12-24-2023, 09:06 AM
Last Post: Ccssid
  No Luck flashing WaspOS MadHatter 0 1,645 12-11-2023, 01:19 AM
Last Post: MadHatter
  Watchmate doesn't connect to PT anymore jojuma 1 2,523 02-07-2023, 02:43 AM
Last Post: azymohliad
  can anyone suggest their working Linux bluetooth USB dongles to connect to Pinetime? jahway603 4 5,268 07-27-2022, 07:38 PM
Last Post: jahway603
Question [question] how to restore PineTime to a factory state after flashing non-OTA/directly ITCactus 2 4,450 04-11-2022, 05:03 AM
Last Post: ITCactus
  Gadgetbridge vs RF Connect ronaldheld 2 4,122 03-30-2022, 06:14 AM
Last Post: danimations
Question Which companion apps work best for flashing firmware and pairing/syncing w/ Pinetime? danimations 0 2,790 03-28-2022, 08:22 PM
  PineTime re-connect to PInephone kmsgli 8 9,480 01-01-2022, 08:05 PM
Last Post: kmsgli
  BT WONT CONNECT mindwave 8 10,302 11-19-2021, 03:18 AM
Last Post: danielt
