Flashing with RF Connect
(04-11-2022, 03:53 AM)ronaldheld Wrote: I cannot flash 1.9.0. it stops at 13%  I tried 1.8.0 and got the same results.  Is this due to recent updates to RF Connect?
it could be you experience this issue...
if it's on android, try Gadgetbridge app (or Siglo on linux),
and like JF002 suggested,
Quote:So, as other said, reboot your watch between every attempts, try with another phone/computer and another companion app and, if possible, analyze and debug to find out why the transfer failed and how we could improve the code ;-)
Also, note that most of the companion app will only accept the DFU (.zip) file, while Amazfish only supports the image (.bin) file.
Away
Flashing with RF Connect - by ronaldheld - 04-11-2022, 03:53 AM
RE: Flashing with RF Connect - by ITCactus - 04-11-2022, 04:58 AM
RE: Flashing with RF Connect - by ronaldheld - 04-22-2022, 03:44 AM
RE: Flashing with RF Connect - by ITCactus - 04-22-2022, 03:55 AM
RE: Flashing with RF Connect - by ronaldheld - 04-26-2022, 06:49 AM
RE: Flashing with RF Connect - by wibble - 04-26-2022, 07:23 AM
RE: Flashing with RF Connect - by ITCactus - 04-26-2022, 08:19 AM
RE: Flashing with RF Connect - by ronaldheld - 04-27-2022, 04:02 AM
RE: Flashing with RF Connect - by ITCactus - 04-27-2022, 06:00 AM
RE: Flashing with RF Connect - by ronaldheld - 04-27-2022, 03:21 PM
RE: Flashing with RF Connect - by ITCactus - 04-28-2022, 03:25 AM
RE: Flashing with RF Connect - by ronaldheld - 04-28-2022, 03:56 AM
RE: Flashing with RF Connect - by ITCactus - 04-28-2022, 04:27 AM
  Flashing chris.burmajster 2 1,394 03-24-2025, 06:18 PM
Last Post: chris.burmajster
  Connect to Google Fit on Android? Ccssid 0 1,786 12-24-2023, 09:06 AM
Last Post: Ccssid
  No Luck flashing WaspOS MadHatter 0 1,645 12-11-2023, 01:19 AM
Last Post: MadHatter
  Watchmate doesn't connect to PT anymore jojuma 1 2,523 02-07-2023, 02:43 AM
Last Post: azymohliad
  can anyone suggest their working Linux bluetooth USB dongles to connect to Pinetime? jahway603 4 5,268 07-27-2022, 07:38 PM
Last Post: jahway603
Question [question] how to restore PineTime to a factory state after flashing non-OTA/directly ITCactus 2 4,450 04-11-2022, 05:03 AM
Last Post: ITCactus
  Gadgetbridge vs RF Connect ronaldheld 2 4,122 03-30-2022, 06:14 AM
Last Post: danimations
Question Which companion apps work best for flashing firmware and pairing/syncing w/ Pinetime? danimations 0 2,790 03-28-2022, 08:22 PM
  PineTime re-connect to PInephone kmsgli 8 9,480 01-01-2022, 08:05 PM
Last Post: kmsgli
  BT WONT CONNECT mindwave 8 10,302 11-19-2021, 03:18 AM
Last Post: danielt
