Found newer firmware for broadcom wifi (brcmfmac43456-sdio)
(06-26-2025, 10:35 PM)reukiodo Wrote: What command are you using to view all this information in the .bin file ?
He's using strings, version information is at the end of output
For the record, the firmware that shipped with my PBP on the Manjaro eMMC has a different version than any in the cobratbq repository, older than most. Note empty revision ® in version field.
43455c5-roml/43455_sdio-43455_ftrs-bcm_ftrs-ag-pno-aoe-pktfilter-srfast-pktctx-lpc-pwropt-wapi-mfp-clm_4335_ss-txpwr-wepso-noccxaka-sarctrl-gscan-linkstat-pwrstats-ak-idauth-idsup-ndoe-mchan-wfds-neeze-akiss
Version: 7.45.96.27 (42b546f@shgit) (r)
CRC: 4638b934
Date: Fri 2018-09-07 14:34:47 CST
Ucode Ver: 1043.20702
FWID: 01-c958c084
It has the same bugs documented for 7.45.96.0.
RE: Found newer firmware for broadcom wifi (brcmfmac43456-sdio) - by remph - 07-04-2025, 07:46 AM
  Unable to install Debian Bullseye because of missing wifi firmware Pino64 8 11,427 06-26-2025, 09:20 PM
Last Post: reukiodo
  pbp with manjaro arm seems to not find any hardware[no wifi, blutooth or battery] frank_philip 4 3,668 03-15-2025, 01:47 AM
Last Post: frank_philip
  Void Linux: missing firmware from pinebookpro-firmware? remph 0 1,968 12-15-2024, 01:58 PM
Last Post: remph
  Manjaro ARM: enabling external monitors & fixing Broadcom WiFi after updating trifleneurotic 2 3,752 11-14-2023, 10:57 AM
Last Post: trifleneurotic
  5GHz wifi not working snorwood 11 12,519 01-16-2023, 03:41 PM
Last Post: ehcorn
  Pinebook Pro wifi not working Queliffrel 1 2,832 11-30-2022, 06:30 AM
Last Post: myself600
  WiFi stopped on Pinebook Pro after update tkudog 3 5,435 11-24-2022, 04:32 PM
Last Post: tkudog
  Archlinux - missing firmware for wifi adapter RudderDuck 9 10,530 11-07-2022, 04:56 PM
Last Post: wgahnagl
  newer ""emmc-installer" images (manjaro xfce) magistral 1 2,509 10-10-2022, 06:22 AM
Last Post: maxjrh
  Help with Kali Linux wifi not working but works with Manjaro PineSupporter 2 4,737 08-25-2022, 02:15 PM
Last Post: Niko
