Distro for writers, k & m, LibreOffice, PostmarketOS?
I would go with any of well supported distros. I do not think Fedora is among those, not on PinePhone anyway.
I am not sure how well OpenOffice will run on any distro (even well supported one) due to the fact it's probably not optimized for small screen, and it's also a bit 'heavy' of an application.[0]
So, personally, I would use a good text editor. Which have a lot of advantages. However, any truly powerful text editor is going to have some amount of learning curve (and the more power, the more curve). I am a huge fan and proponent of Emacs for example, but she's a hairy beast! Some people like vim but you won't be able to exit out of it. There are many others which may be easier to start with, but the aforementioned 'big 2' are true power user tools which require some investment to master. It's sort of tangential whether or not you think that investment is worth it in the long run. Personally I do, but YMMV.
[0] In fairness, I do not use it (on PinePhone) so I could be totally wrong. This is just what I suspect.
Cheers,
TRS-80
Protocols, not Platforms
RE: Distro for PPhone writers, keyboard & mouse (no touch, but office?) - by TRS-80 - 04-30-2022, 05:48 PM
  Struggle to install LibreOffice on the PinePhone Peter Gamma 50 58,452 07-26-2024, 10:35 PM
Last Post: Peter Gamma
  Boxes at startup of LibreOffice cannot be executed Peter Gamma 0 1,675 06-12-2022, 03:02 AM
  Pinephone: Is there a frugal distro? orbital 2 3,963 05-27-2022, 09:34 PM
Last Post: orbital
  Bluetooth low energy & ANT+ sports sensors Pinephone distro? Peter Gamma 34 68,167 12-08-2021, 04:50 AM
Last Post: thibaultmol
  What distro should I try right now? dan640 1 3,982 02-14-2021, 06:35 AM
Last Post: evilbunny
  Low Battery indication (Manjaro/PostmarketOS with phosh) MamlinAV 3 6,786 12-16-2020, 03:44 AM
Last Post: dukla2000
  Can I use UT apps with another distro ? Sanexom 2 5,077 07-08-2020, 06:55 AM
Last Post: patrickjquinn
  After installing CRUST, what does a distro need to do to get wake on modem working? Subsentient 4 9,100 07-06-2020, 04:32 AM
Last Post: Alefnode
  Selecting a distro for a 32-bit application jfloren 3 7,145 02-04-2020, 02:03 PM
