Power issue with the Pro
I've received the Pro for doing some light dev/messing around with, and to use as a daily sms unit. I got time to pull battery contact protector strip, and plug the unit in last night, all much like the 'regular' pinephone. I did notice that the battery was at 50%, which I thought would be expected, it needing a top off. I also noted it was draining, slowly, as I set up wifi et cetera -pretty much wifi and the pine64 arm wallpaper. Weird, but I can swap batteries if need be was my thinking, were it the battery. I started the update process, and let it do its thing, not checking it again until this afternoon, leaving the phone connected to a vanilla wall power usb plug that is surge-protected. There is now no response to button presses, no change if I swap to the battery from the non-Pro model, no friendly red/green led when the usb cable is connected. My first thought was, hell, failure to update, any number of reasons, I can install the OS myself, not a big deal. Upon further examination, this may be the case, or there are any number of other possibilities that I can think of. The older pinephone will boot up with either battery, so I am going to fully charge both, leaving the Pro unpowered overnight, and see what happens in the morning. Honestly, the battery shouldn't, in my mind, be the issue, if the unit is connected to external power, be it PC or wall plug. I hope I've given a detailed enough description, I am doing my best to not work on other things while typing this. Battery troubleshooting aside, does anyone have any thoughts?
Power issue with the Pro - by Freitag - 04-05-2022, 03:43 PM
RE: Power issue with the Pro - by LPIZ - 04-25-2022, 06:14 AM
  suggestions for power/battery consumption data logger for community to compare? dchang0 6 3,852 01-02-2025, 09:46 PM
  Tow-Boot issue Barugon 1 2,899 10-22-2022, 03:22 AM
Last Post: AndrewBlackmiller
  Would disabling all cpu's except one save power on the PPP? rp3 3 4,527 08-27-2022, 01:10 AM
Last Post: uzanto
  Guide to power off the Pinephone Pro on low battery Ulfnic 5 7,354 02-11-2022, 02:47 PM
Last Post: dexy
  Battery charging issue kileel 1 3,134 12-13-2021, 03:58 PM
Last Post: kileel
