Current State of PIne Phone Pro
#24
(03-23-2022, 09:03 AM)tckosvic Wrote:
(03-19-2022, 09:00 AM)fxc Wrote:
(03-19-2022, 08:14 AM)ojimek Wrote: I'm also a pinephone user, using it as my main phone. I did buy a pinephone pro in january and got it in february. Less than a month after, it was dead. Not dead dead, but the sim card slot is broken, so now it's basically just an overpriced raspberry pi with a touchscreen.
I'm not the only one either, if you look at this forum, you'll find plenty of people mentioning having problems with the sim card slot, which is apparently a poor component. I haven't seen pine64 ackowledging it so far. So I wouldn't recommend to buy it for now, until the problem is acknowledged and fixed.
There is no SIM card slot issue. Occasionally people put empty SIM adapters in the slot or lose the SIM from the adapter (both cases user errors), in which case the contact pins can bent or break if the user applies brute force to remove the card again (second user error). The combined SIM card slot and microSD card reader is used since the original PinePhone and received a slight upgrade with the Pro, so I don't expect Pine64 folks to swap that component (and I doubt there are practical alternatives) to reduce user errors. Just be careful, don't apply force. I think that is common sense.
ojimek, please refrain from repeating accusations in further replies and wishing people a broken device, that kind of language is really unasked for. I would suggest you to have a look at the community rules.
It is stated above that there is no sim card issue.  There is no sim card slot issue until you have to use it, and use it, and use it. Then there is a sim card slot issue. Until the boot issues are fixed and you can just boot from eMMC and install a sd card (once) to use for extra storage, sim card slot issues will reappear here.  In 6 or so years with an android phone, I put the sim card in once and an sd card in once and never touched them.
I have a borked sim card slot in PPP due to repeated inserts/removals.  I can't get pinephone company staff to even supply a part number to get a replacement after multiple emails.  My PPP is on the shelf.  Amazingly my PP is functioning well.  It charges when you connect it through usb rather than discharging.  It runs off of dedicated built-in memory.  It doesn't automatically continually reboot when you are trying to charge it. Everything except MMS works to some extent. Even the camera.  PP is using manjaro-phosh,beta23.
We have secure some PinePhone and PinePhone Pro microSD/SIM card connectors from supplier. We don't want to place this in Pine Store due to this is limited quantity. If you have the sim slot issue and able to ask local repair shop to make the repair, support team can file a request to send out this spare part. When file the support time at https://support.pine64.org, please provide your order number and sim slot damage photo shows, support team will help up on this arrangement. Please note that this spare part is free but you still need to pay for the Pine Store standard shipping. Due to this is a special arrangement, support team will not help up on combine shipment type of request.
Current State of PIne Phone Pro - by kmsgli - 03-19-2022, 07:15 AM
RE: Current State of PIne Phone Pro - by ojimek - 03-19-2022, 08:14 AM
RE: Current State of PIne Phone Pro - by fxc - 03-19-2022, 09:00 AM
RE: Current State of PIne Phone Pro - by kmsgli - 03-19-2022, 09:52 PM
RE: Current State of PIne Phone Pro - by bcnaz - 03-20-2022, 01:27 AM
RE: Current State of PIne Phone Pro - by kmsgli - 03-20-2022, 10:32 AM
RE: Current State of PIne Phone Pro - by fxc - 03-20-2022, 04:42 PM
RE: Current State of PIne Phone Pro - by kmsgli - 03-20-2022, 06:43 PM
RE: Current State of PIne Phone Pro - by tckosvic - 03-23-2022, 09:03 AM
RE: Current State of PIne Phone Pro - by tllim - 04-06-2022, 03:22 PM
RE: Current State of PIne Phone Pro - by wibble - 04-07-2022, 07:03 AM
RE: Current State of PIne Phone Pro - by tckosvic - 04-08-2022, 08:54 AM
RE: Current State of PIne Phone Pro - by fxc - 04-08-2022, 03:27 PM
RE: Current State of PIne Phone Pro - by tckosvic - 04-09-2022, 09:56 AM
RE: Current State of PIne Phone Pro - by bcnaz - 03-21-2022, 04:36 PM
RE: Current State of PIne Phone Pro - by kmsgli - 03-25-2022, 05:04 PM
RE: Current State of PIne Phone Pro - by kmsgli - 04-07-2022, 04:43 AM
RE: Current State of PIne Phone Pro - by Airdale - 04-07-2022, 05:05 PM
RE: Current State of PIne Phone Pro - by brb78 - 03-22-2022, 10:14 AM
RE: Current State of PIne Phone Pro - by kmsgli - 03-22-2022, 10:48 AM
RE: Current State of PIne Phone Pro - by Dinobot - 03-24-2022, 06:50 PM
RE: Current State of PIne Phone Pro - by Ralt - 03-25-2022, 11:03 PM
RE: Current State of PIne Phone Pro - by kmsgli - 03-26-2022, 06:39 AM
RE: Current State of PIne Phone Pro - by bcnaz - 03-26-2022, 09:25 PM
RE: Current State of PIne Phone Pro - by expant - 03-27-2022, 02:27 AM
RE: Current State of PIne Phone Pro - by fxc - 03-28-2022, 11:35 AM
RE: Current State of PIne Phone Pro - by bcnaz - 04-10-2022, 06:34 PM
RE: Current State of PIne Phone Pro - by Chief - 04-11-2022, 08:51 PM
RE: Current State of PIne Phone Pro - by kmsgli - 04-12-2022, 05:36 AM
RE: Current State of PIne Phone Pro - by apink - 10-23-2022, 09:56 PM
RE: Current State of PIne Phone Pro - by wibble - 04-15-2022, 07:15 AM
RE: Current State of PIne Phone Pro - by apink - 10-21-2022, 03:37 PM
Question Phone call with the pinephone pro dfs 5 4,192 02-10-2024, 09:54 PM
  PPP used with smart phone gaming fan. DaForest 3 807 11-19-2023, 05:17 AM
Last Post: crocspot
  Is the pine phone usable as a daily driver now? gautamb11 18 4,368 10-27-2023, 12:46 AM
Last Post: gregb49
  Pine Phone Pro: Mobian+plasma mobile GabrieleMax 2 1,551 04-30-2023, 05:03 AM
Last Post: diederik
  pine phone pro won't start robb777 2 1,377 01-25-2023, 04:38 PM
Last Post: emsyr
  Was the Pine Phone Pro you got from DHL new? theForce 3 2,029 10-31-2022, 04:26 PM
Last Post: fxc
  Internet is not working on Pine Pro phone caroljames972022 0 862 09-16-2022, 06:25 AM
Last Post: caroljames972022
  Loud echo on receiving phone when called TheRealThor 3 2,102 08-09-2022, 10:09 AM
Last Post: tckosvic
  Phone not reading sim For_lack_of_a_better_name 6 4,218 06-09-2022, 01:00 PM
Last Post: daveman1010220
  New user. Very excited as this is my first linux phone...have a few questions 98cwitr 4 2,588 05-25-2022, 06:31 AM
Last Post: 98cwitr
