Icecat on Mobian on PinePhone
(03-19-2022, 05:44 AM)wibble Wrote: IIRC the gentoo build process does an early test for >=4GB RAM before attempting to compile the major browsers, and even then you'll run into heavy swap use. You can probably either build natively with something like an 8GB Pi4, or crosscompile on a more capable x86_64 machine which is almost certainly how the mobian packages are built. That should allow you to build a package with all the correct dependencies to run.
https://wiki.debian.org/CrossCompiling
Thank you for your reply!
I appreciate the concept of (cross)compiling and after a quick skim of your link, don’t feel like I would have too much difficulty following along if I can already follow native, on-target compilation instructions, however what I’m really not sure about is how I would then transfer the build from the build box to the PinePhone - would it be as simple as copying a single package (or entire build directory?) to a USB and then from there to the PinePhone via a hub? The only other device I have with a Linux environment is a 8Gb RPi 4 but was discouraged from trying to compile on that by stackexchange posts stating that 16Gb RAM with 8Gb ZRAM swap was needed.
Is this the only realistically “correct” way to go about getting Icecat on Mobian on PinePhone, or are there some further, non-symlink steps I can take with the approach I took installing the prebuilt package from The Fedora Project?
Icecat on Mobian on PinePhone - by 3460p - 03-18-2022, 08:20 AM
RE: Icecat on Mobian on PinePhone - by wibble - 03-19-2022, 05:44 AM
RE: Icecat on Mobian on PinePhone - by 3460p - 03-19-2022, 12:01 PM
RE: Icecat on Mobian on PinePhone - by wibble - 03-20-2022, 08:13 AM
RE: Icecat on Mobian on PinePhone - by 3460p - 04-21-2022, 08:54 AM
RE: Icecat on Mobian on PinePhone - by 3460p - 04-23-2022, 09:02 AM
RE: Icecat on Mobian on PinePhone - by clover - 04-23-2022, 02:21 PM
RE: Icecat on Mobian on PinePhone - by 3460p - 04-28-2022, 08:00 AM
RE: Icecat on Mobian on PinePhone - by wibble - 04-25-2022, 03:53 AM
RE: Icecat on Mobian on PinePhone - by wibble - 04-29-2022, 02:56 AM
RE: Icecat on Mobian on PinePhone - by 3460p - 05-05-2022, 01:14 PM
RE: Icecat on Mobian on PinePhone - by wibble - 05-06-2022, 05:07 AM
RE: Icecat on Mobian on PinePhone - by 3460p - 05-06-2022, 11:04 AM
RE: Icecat on Mobian on PinePhone - by wibble - 05-07-2022, 04:28 AM
RE: Icecat on Mobian on PinePhone - by 3460p - 05-14-2022, 04:29 AM
RE: Icecat on Mobian on PinePhone - by wibble - 05-15-2022, 05:41 AM
  bookworm vs trixie discussion for mobian in pinephone regular. zetabeta 24 2,455 05-05-2024, 07:42 AM
Last Post: zetabeta
  Mobian repository status henrythemouse 16 8,962 04-10-2024, 10:02 AM
Last Post: diederik
  cant verify mobian image at website gnugpg penguins_rule 0 154 03-18-2024, 08:54 PM
Last Post: penguins_rule
  unofficial kali linux for pinephone help needed pinesmell 5 3,707 01-08-2024, 02:50 PM
Last Post: ERPlegend
  mobian installed to eMMC - how to install tow-boot grump_fiddle_reinstall 6 2,070 11-22-2023, 11:46 AM
Last Post: aLoop100o
  What actions needed to keep on mobian testing user641 3 1,868 09-05-2023, 06:44 AM
  Mobian boot failed with zstd message after upgrade. Mahgue 0 650 09-01-2023, 11:29 AM
Last Post: Mahgue
  how to update mobian over tor vusra 13 7,049 07-09-2023, 08:57 PM
Last Post: vusra
  opensnitch outbound firewall now works on mobian vusra 2 1,934 07-09-2023, 01:37 AM
Last Post: vusra
  Using Nativefier on PP64 with Mobian paulcarton 0 648 07-05-2023, 03:57 AM
Last Post: paulcarton
