Armbian and LibreELEC and AltLinux for Quartz64
#98
(12-13-2022, 04:54 PM)acj_ Wrote: I am attempting to run Armbian on a Pine64 Quartz64.  I haven't read through all of everyone's forum posts, and this might have been addressed...
I found: https://forum.pine64.org/showthread.php?tid=16312 which links to https://users.armbian.com/balbes150/quartz64/  from there, there are a number of relatively recent disk images for Quartz64 model A boards.  I am able to get just about any of them functioning; e.g. burned to emmc or sd, and the board is able to boot.  The two issues that I have noticed are:
+ The board is an 8GB mem board, but for some of the images, it appears to the system to only have 2GB
+ General performance for any of the images is abysmal
    From balbes150's images: using, Armbian_22.11.0-trunk_Quartz64a_sid_current_5.19.17.img.xz, GeekBench produces...
        --> https://browser.geekbench.com/v5/cpu/19280197
    Even forcing the board to run at max Mhz (1800), the performance is still the same.
Has anyone else seen similar performance issues and incorrect memory being reported?
Thanks in advance for the help...
Following up on my own post.  I chatted with a few Pine64 folks on Discord, and they agreed that the benchmark numbers are reasonable for the Q64a and the memory issues maybe because of u-boot that Armbian uses.
RE: Armbian for Quartz64 - by shaggy013 - 03-15-2022, 01:56 PM
RE: Armbian for Quartz64 - by balbes150 - 03-16-2022, 03:48 AM
RE: Armbian for Quartz64 - by shaggy013 - 03-16-2022, 04:58 AM
RE: Armbian for Quartz64 - by shaggy013 - 03-16-2022, 07:11 AM
RE: Armbian for Quartz64 - by balbes150 - 03-16-2022, 07:21 AM
RE: Armbian for Quartz64 - by shaggy013 - 03-16-2022, 07:25 AM
RE: Armbian for Quartz64 - by balbes150 - 03-17-2022, 02:31 AM
RE: Armbian for Quartz64 - by balbes150 - 03-17-2022, 05:19 AM
RE: Armbian for Quartz64 - by balbes150 - 03-21-2022, 01:28 AM
RE: Armbian for Quartz64 - by igorp - 03-23-2022, 04:14 AM
RE: Armbian for Quartz64 - by balbes150 - 04-01-2022, 07:36 AM
RE: Armbian and LibreELEC and AltLinux for Quartz64 - by acj_ - 12-13-2022, 09:12 PM
  irradium (based on crux linux) Quartz64 riscv64, aarch64 mara 6 14,197 09-01-2025, 10:26 AM
  How does CPU frequency scaling work on the Quartz64 pugzarecute 0 1,513 07-30-2025, 07:19 AM
Last Post: pugzarecute
  USB on Quartz64 Zero litbulb 0 1,087 11-13-2024, 08:16 AM
Last Post: litbulb
  DietPi OS for Quartz64 MichaIng 47 41,335 08-08-2024, 07:42 AM
Last Post: ifreislich
  slarm64 (unofficial slackware) Quartz64 RK3566 (aarch64) mara 56 69,976 10-17-2023, 10:55 AM
  quartz64-a - on-board SATA port problems manning 2 3,662 09-14-2023, 04:22 PM
Last Post: manning
  How the reset Quartz64-b onboard memory (emmc) beepy 2 3,114 07-20-2023, 10:44 PM
Last Post: beepy
  Armbian RAM issue JambonLeVrai 2 3,718 02-12-2023, 06:48 AM
Last Post: diederik
  crux-arm Quartz64 RK3566 (aarch64) mara 5 8,266 10-29-2022, 06:55 AM
  Ov5647 camera attached via csi to Quartz64 /Soquartz Randomuser 0 2,516 07-21-2022, 01:08 PM
Last Post: Randomuser
