Armbian and LibreELEC and AltLinux for Quartz64
#82
(12-04-2022, 05:09 AM)bosi564 Wrote: I'll quickly add a bit more information, because I'm not sure what will be helpful.  I'll have time later to do some tests (after 8-10 hours from this post).
My quartz64 has 8 gigabytes of RAM. I think I read somewhere in the wiki that early tests were done on devices with 4 gigabytes and there was no guarantee that video will work on devices with 8GB, but after a quick search I couldn't verify this info.
Quote:By the way, have other images been recorded on your SD card before? Perhaps the reason is the "remnants" of old systems that leave a backup copy of GPT or other data. Try to completely clean the SD card (using the DD utility) before writing the EDK2 image.
No, it was a brand new microSD from the store dedicated to video recording. But I'll wipe it clean later just to be sure.
The usb stick was used for some other linux/bsd installations, but I'll wipe it clean too.
I found in the source code and in the release tags that there were two versions with 4GB and 8GB for Quartz64 in the beginning. Try the options from the website for the 8GB version.
If this works, I'll try adding another option for the 8GB version.
https://github.com/jaredmcneill/quartz64_uefi/releases
RE: Armbian for Quartz64 - by shaggy013 - 03-15-2022, 01:56 PM
RE: Armbian for Quartz64 - by balbes150 - 03-16-2022, 03:48 AM
RE: Armbian for Quartz64 - by shaggy013 - 03-16-2022, 04:58 AM
RE: Armbian for Quartz64 - by shaggy013 - 03-16-2022, 07:11 AM
RE: Armbian for Quartz64 - by balbes150 - 03-16-2022, 07:21 AM
RE: Armbian for Quartz64 - by shaggy013 - 03-16-2022, 07:25 AM
RE: Armbian for Quartz64 - by balbes150 - 03-17-2022, 02:31 AM
RE: Armbian for Quartz64 - by balbes150 - 03-17-2022, 05:19 AM
RE: Armbian for Quartz64 - by balbes150 - 03-21-2022, 01:28 AM
RE: Armbian for Quartz64 - by igorp - 03-23-2022, 04:14 AM
RE: Armbian for Quartz64 - by balbes150 - 04-01-2022, 07:36 AM
RE: Armbian and LibreELEC and AltLinux for Quartz64 - by balbes150 - 12-05-2022, 08:17 AM
  irradium (based on crux linux) Quartz64 riscv64, aarch64 mara 6 14,197 09-01-2025, 10:26 AM
  How does CPU frequency scaling work on the Quartz64 pugzarecute 0 1,513 07-30-2025, 07:19 AM
Last Post: pugzarecute
  USB on Quartz64 Zero litbulb 0 1,087 11-13-2024, 08:16 AM
Last Post: litbulb
  DietPi OS for Quartz64 MichaIng 47 41,335 08-08-2024, 07:42 AM
Last Post: ifreislich
  slarm64 (unofficial slackware) Quartz64 RK3566 (aarch64) mara 56 69,976 10-17-2023, 10:55 AM
  quartz64-a - on-board SATA port problems manning 2 3,662 09-14-2023, 04:22 PM
Last Post: manning
  How the reset Quartz64-b onboard memory (emmc) beepy 2 3,114 07-20-2023, 10:44 PM
Last Post: beepy
  Armbian RAM issue JambonLeVrai 2 3,718 02-12-2023, 06:48 AM
Last Post: diederik
  crux-arm Quartz64 RK3566 (aarch64) mara 5 8,266 10-29-2022, 06:55 AM
  Ov5647 camera attached via csi to Quartz64 /Soquartz Randomuser 0 2,516 07-21-2022, 01:08 PM
Last Post: Randomuser
