Armbian and LibreELEC and AltLinux for Quartz64
#75
(12-02-2022, 04:22 PM)bosi564 Wrote: My Quartz64 model A finally showed a beautiful bootup picture on my FullHD monitor.
Nice progress!
Well, for some reason it didn't boot within a minute or so, but I'm tired and will leave it as it is for the night.
I did see the grub menu and after a few log lines showing it's loading the initramfs I got to the three lines with "EFI stub - something" and the third was like "EFI stub: exiting boot services".
As a side note: I tried moving the usb stick to one of the USB 3.0 ports (the bottom right), but GRUB didn't load and I got to see this TianoCore EDK II menu for the first time.
The files I've downloaded are:
1. Armbian_22.11.0-trunk_Quartz64a_sid_edge_6.1.0.img
2. QUARTZ64_EFI.img
written on both a usb stick and sd card as per the instructions on the other forum.
1. Try to connect the media with the system to all USB ports.
2. Which USB media do you use? I recommend trying the simplest USB 2.0 flash drive.
3. Which devices are connected to USB? Try to disconnect all USB devices at the time of startup, except the USB flash drive with the system, if the system starts, they can then be connected.
4. Try using the Ubuntu variant (Cli or XFCE). I have not tested Debian and there is a possibility of an error in the image.
I found the reason why the Debian image doesn't run. need to manually make changes to the settings. Use Ubuntu image.
RE: Armbian for Quartz64 - by shaggy013 - 03-15-2022, 01:56 PM
RE: Armbian for Quartz64 - by balbes150 - 03-16-2022, 03:48 AM
RE: Armbian for Quartz64 - by shaggy013 - 03-16-2022, 04:58 AM
RE: Armbian for Quartz64 - by shaggy013 - 03-16-2022, 07:11 AM
RE: Armbian for Quartz64 - by balbes150 - 03-16-2022, 07:21 AM
RE: Armbian for Quartz64 - by shaggy013 - 03-16-2022, 07:25 AM
RE: Armbian for Quartz64 - by balbes150 - 03-17-2022, 02:31 AM
RE: Armbian for Quartz64 - by balbes150 - 03-17-2022, 05:19 AM
RE: Armbian for Quartz64 - by balbes150 - 03-21-2022, 01:28 AM
RE: Armbian for Quartz64 - by igorp - 03-23-2022, 04:14 AM
RE: Armbian for Quartz64 - by balbes150 - 04-01-2022, 07:36 AM
RE: Armbian and LibreELEC and AltLinux for Quartz64 - by balbes150 - 12-03-2022, 12:36 AM
  irradium (based on crux linux) Quartz64 riscv64, aarch64 mara 6 14,197 09-01-2025, 10:26 AM
  How does CPU frequency scaling work on the Quartz64 pugzarecute 0 1,513 07-30-2025, 07:19 AM
Last Post: pugzarecute
  USB on Quartz64 Zero litbulb 0 1,087 11-13-2024, 08:16 AM
Last Post: litbulb
  DietPi OS for Quartz64 MichaIng 47 41,335 08-08-2024, 07:42 AM
Last Post: ifreislich
  slarm64 (unofficial slackware) Quartz64 RK3566 (aarch64) mara 56 69,976 10-17-2023, 10:55 AM
  quartz64-a - on-board SATA port problems manning 2 3,662 09-14-2023, 04:22 PM
Last Post: manning
  How the reset Quartz64-b onboard memory (emmc) beepy 2 3,114 07-20-2023, 10:44 PM
Last Post: beepy
  Armbian RAM issue JambonLeVrai 2 3,718 02-12-2023, 06:48 AM
Last Post: diederik
  crux-arm Quartz64 RK3566 (aarch64) mara 5 8,266 10-29-2022, 06:55 AM
  Ov5647 camera attached via csi to Quartz64 /Soquartz Randomuser 0 2,516 07-21-2022, 01:08 PM
Last Post: Randomuser
