Armbian and LibreELEC and AltLinux for Quartz64
#38
(05-13-2022, 05:17 AM)shaggy013 Wrote: LibreELEC-ARMv8.aarch64-11.0-devel-20220512120655-8bd19d9-rk3566-quartz64a
Now I checked the LE image - everything works. HDMI is working, video decodes with HW. there is no kernel panic, what you see are service messages, if there was a kernel panic, you would not be able to output DMESNG. And the memory speed is also fine, it is more than enough for the system to work (including for software decoding of the 1440p format). Check your monitor so that it meets the operating conditions of the main core (1080p).
RE: Armbian for Quartz64 - by shaggy013 - 03-15-2022, 01:56 PM
RE: Armbian for Quartz64 - by balbes150 - 03-16-2022, 03:48 AM
RE: Armbian for Quartz64 - by shaggy013 - 03-16-2022, 04:58 AM
RE: Armbian for Quartz64 - by shaggy013 - 03-16-2022, 07:11 AM
RE: Armbian for Quartz64 - by balbes150 - 03-16-2022, 07:21 AM
RE: Armbian for Quartz64 - by shaggy013 - 03-16-2022, 07:25 AM
RE: Armbian for Quartz64 - by balbes150 - 03-17-2022, 02:31 AM
RE: Armbian for Quartz64 - by balbes150 - 03-17-2022, 05:19 AM
RE: Armbian for Quartz64 - by balbes150 - 03-21-2022, 01:28 AM
RE: Armbian for Quartz64 - by igorp - 03-23-2022, 04:14 AM
RE: Armbian for Quartz64 - by balbes150 - 04-01-2022, 07:36 AM
RE: Armbian and LibreELEC and AltLinux for Quartz64 - by balbes150 - 05-13-2022, 05:35 AM
  irradium (based on crux linux) Quartz64 riscv64, aarch64 mara 6 14,182 09-01-2025, 10:26 AM
  How does CPU frequency scaling work on the Quartz64 pugzarecute 0 1,510 07-30-2025, 07:19 AM
Last Post: pugzarecute
  USB on Quartz64 Zero litbulb 0 1,086 11-13-2024, 08:16 AM
Last Post: litbulb
  DietPi OS for Quartz64 MichaIng 47 41,302 08-08-2024, 07:42 AM
Last Post: ifreislich
  slarm64 (unofficial slackware) Quartz64 RK3566 (aarch64) mara 56 69,914 10-17-2023, 10:55 AM
  quartz64-a - on-board SATA port problems manning 2 3,656 09-14-2023, 04:22 PM
Last Post: manning
  How the reset Quartz64-b onboard memory (emmc) beepy 2 3,113 07-20-2023, 10:44 PM
Last Post: beepy
  Armbian RAM issue JambonLeVrai 2 3,713 02-12-2023, 06:48 AM
Last Post: diederik
  crux-arm Quartz64 RK3566 (aarch64) mara 5 8,257 10-29-2022, 06:55 AM
  Ov5647 camera attached via csi to Quartz64 /Soquartz Randomuser 0 2,514 07-21-2022, 01:08 PM
Last Post: Randomuser
